주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ring Stick Up Cam Camera Replacement
필요한 것
  1. Ring Stick Up Cam Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the six 6mm Phillips #00 screws from the back of the device.
    댓글 쓰기
  2. Ring Stick Up Cam Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Pry off the aluminum plate using a plastic opening tool.
    댓글 쓰기
  3. Ring Stick Up Cam Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
    댓글 쓰기
  4. Ring Stick Up Cam Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Pry off the back cover using a plastic opening tool.
    댓글 쓰기
  5. Ring Stick Up Cam Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Disconnect the battery power leads using a plastic opening tool.
    댓글 쓰기
  6. Ring Stick Up Cam Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
    댓글 쓰기
  7. Ring Stick Up Cam Camera Replacement, Camera: 7 단계, 이미지 1개 중 1개
    • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
    댓글 쓰기
  8. Ring Stick Up Cam Camera Replacement: 8 단계, 이미지 1개 중 1개
    • Disconnect the ribbon connector shown in the photo.
    댓글 쓰기
  9. Ring Stick Up Cam Camera Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the motherboard from the device by hand.
    댓글 쓰기
  10. Ring Stick Up Cam Camera Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
    • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
    댓글 쓰기
  11. Ring Stick Up Cam Camera Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the three plastic spacers shown in the photo by hand.
    댓글 쓰기
  12. Ring Stick Up Cam Camera Replacement: 12 단계, 이미지 1개 중 1개
    • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
    댓글 쓰기
  13. Ring Stick Up Cam Camera Replacement: 13 단계, 이미지 1개 중 1개
    • Lift the camera board out of the housing using your hand.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ao Li
회원 가입일: 02/06/19
245 평판
안내서 1개를 작성함
UC Davis, Team S18-G3, Lore Winter 2019 UC Davis, Team S18-G3, Lore Winter 2019 회원
UCD-LORE-W19S18G3
3 회원들
안내서 8개를 작성함
2가이드 댓글
Where can I purchase a new lens?
Javier Casas - 답글 공유
Any ideas where to get a new lens?
Mete Doguoglu - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 47
전체 시간: 5,360
