주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ring Stick Up Cam Microphone Replacement
필요한 것
    1. Ring Stick Up Cam Microphone Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Remove the six 6mm Phillips #00 screws from the back of the device.
      댓글 쓰기
    2. Ring Stick Up Cam Microphone Replacement: 2 단계, 이미지 1개 중 1개
      • Pry off the aluminum plate using a plastic opening tool.
      댓글 쓰기
    3. Ring Stick Up Cam Microphone Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
      댓글 쓰기
    4. Ring Stick Up Cam Microphone Replacement: 4 단계, 이미지 1개 중 1개
      • Pry off the back cover using a plastic opening tool.
      댓글 쓰기
    5. Ring Stick Up Cam Microphone Replacement: 5 단계, 이미지 1개 중 1개
      • Disconnect the battery power leads using a plastic opening tool.
      댓글 쓰기
    6. Ring Stick Up Cam Microphone Replacement: 6 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
      댓글 쓰기
    1. Ring Stick Up Cam Microphone Replacement, Camera: 7 단계, 이미지 1개 중 1개
      • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
      댓글 쓰기
    2. Ring Stick Up Cam Microphone Replacement: 8 단계, 이미지 1개 중 1개
      • Disconnect the ribbon connector shown in the photo.
      댓글 쓰기
    3. Ring Stick Up Cam Microphone Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the motherboard from the device by hand.
      댓글 쓰기
    4. Ring Stick Up Cam Microphone Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
      • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
      댓글 쓰기
    5. Ring Stick Up Cam Microphone Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the three plastic spacers shown in the photo by hand.
      댓글 쓰기
    6. Ring Stick Up Cam Microphone Replacement: 12 단계, 이미지 1개 중 1개
      • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
      댓글 쓰기
    7. Ring Stick Up Cam Microphone Replacement: 13 단계, 이미지 1개 중 1개
      • Lift the camera board out of the housing using your hand.
      댓글 쓰기
    1. Ring Stick Up Cam Microphone Replacement, Microphone: 14 단계, 이미지 1개 중 1개
      • Remove the six silver 4.5mm Phillips #00 screws holding the daughterboard into the device.
      댓글 쓰기
    2. Ring Stick Up Cam Microphone Replacement: 15 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to carefully pry the microphone from the housing.
      댓글 쓰기
    3. Ring Stick Up Cam Microphone Replacement: 16 단계, 이미지 1개 중 1개
      • Use your hands to remove the daughterboard containing the microphone from the housing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Chunyue Liu
회원 가입일: 02/06/19
273 평판
안내서 2개를 작성함
UC Davis, Team S18-G3, Lore Winter 2019 UC Davis, Team S18-G3, Lore Winter 2019 회원
UCD-LORE-W19S18G3
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 24
전체 시간: 3,168
