주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Rival CM4015 Heating Element Replacement
필요한 것
  1. Rival CM4015 Heating Element Replacement, Base Plate: 1 단계, 이미지 2개 중 1개 Rival CM4015 Heating Element Replacement, Base Plate: 1 단계, 이미지 2개 중 2개
    • Remove the three 16 mm tri-point screws from the base plate.
    댓글 쓰기
  2. Rival CM4015 Heating Element Replacement: 2 단계, 이미지 2개 중 1개 Rival CM4015 Heating Element Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the base plate by pressing the plastic body away from the metal plate with your thumbs.
    댓글 쓰기
  3. Rival CM4015 Heating Element Replacement, Power Button: 3 단계, 이미지 1개 중 1개
    • Remove the 8mm Phillips screw that attaches the power button to the inside of the coffee maker.
    댓글 쓰기
  4. Rival CM4015 Heating Element Replacement: 4 단계, 이미지 2개 중 1개 Rival CM4015 Heating Element Replacement: 4 단계, 이미지 2개 중 2개
    • Use a flat head screwdriver to pry the power button from its slot in the body of the device.
    • Make sure the tool is pressed securely under the plastic clip, in order to not break it.
    댓글 쓰기
  5. Rival CM4015 Heating Element Replacement: 5 단계, 이미지 2개 중 1개 Rival CM4015 Heating Element Replacement: 5 단계, 이미지 2개 중 2개
    • Clean both the button and its slot before replacing the power button.
    댓글 쓰기
  6. Rival CM4015 Heating Element Replacement, Heating Element: 6 단계, 이미지 1개 중 1개
    • Remove the two 8 mm Phillips screws from the plastic body.
    댓글 쓰기
  7. Rival CM4015 Heating Element Replacement: 7 단계, 이미지 2개 중 1개 Rival CM4015 Heating Element Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the two 8 mm Phillips screws from the chassis of coffee maker.
    • Pull back the metal backing from the plastic body.
    댓글 쓰기
  8. Rival CM4015 Heating Element Replacement: 8 단계, 이미지 3개 중 1개 Rival CM4015 Heating Element Replacement: 8 단계, 이미지 3개 중 2개 Rival CM4015 Heating Element Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the four 8 mm Phillips screws from the inner plastic body.
    • You will need a long, thin Phillips screw driver to get this deep into the device.
    댓글 쓰기
  9. Rival CM4015 Heating Element Replacement: 9 단계, 이미지 2개 중 1개 Rival CM4015 Heating Element Replacement: 9 단계, 이미지 2개 중 2개
    • Flip the device upside down and remove the outer plastic body from the device by pulling straight up.
    • Take your time to make sure the thin cables within the device don't tear.
    댓글 쓰기
  10. Rival CM4015 Heating Element Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the two 8 mm Phillips screws from the metal backing.
    댓글 쓰기
  11. Rival CM4015 Heating Element Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the 4 springs holding the water tubes by squeezing the 2 prongs together.
    • You may also use pliers for this step if the springs are too strong.
    댓글 쓰기
  12. Rival CM4015 Heating Element Replacement: 12 단계, 이미지 1개 중 1개
    • Bend the heating element back and forth to wiggle the water tubes loose from the plastic.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Michael Murdock
회원 가입일: 10/06/16
279 평판
안내서 2개를 작성함
Cal Poly, Team 10-6, Livingston Fall 2016 Cal Poly, Team 10-6, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S10G6
5 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 29
전체 시간: 650
