주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement
필요한 것
  1. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Receiver: 1 단계, 이미지 1개 중 1개
    • Remove the 4 rubber tabs on the bottom side of the receiver.
    댓글 쓰기
  2. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: 2 단계, 이미지 1개 중 1개
    • Unscrew the four 12 mm screws on the bottom side of the receiver.
    • Use a Phillips #1 screwdriver for this step.
    댓글 쓰기
  3. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: 3 단계, 이미지 2개 중 1개 Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: 3 단계, 이미지 2개 중 2개
    • Remove top casing from the receiver.
    • The receiver top casing is difficult to remove. Internal clasps may have to be broken in order to remove the top casing (this will not effect the device's function)
    댓글 쓰기
  4. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, Receiver LED Light Chip: 4 단계, 이미지 2개 중 1개 Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement, Receiver LED Light Chip: 4 단계, 이미지 2개 중 2개
    • One 10 mm screw is securing the LED 14.14 chip.
    • Unscrew the chip.
    • Use a Phillips #1 Screwdriver for this step.
    댓글 쓰기
  5. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: 5 단계, 이미지 1개 중 1개
    • Using your fingers, gently pull the LED plug out of the mother board.
    댓글 쓰기
  6. Rocketfish RF-WHTIB-A Receiver LED Light Chip Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Gently feed the LED wire under the power supply to completely remove it from the sender.
    • Remove the faulty LED 14.14 chip from the receiver.
    • You may want to use the tweezers to help pull the LED wire out from beneath the power supply.
    댓글 쓰기
결론
To reassemble your device with the new LED light chip, follow these instructions in reverse order.
Once the receiver has been put back together, plug in the device and initiate the connection mode between the sender and receiver to ensure the new LED light chip has been properly assembled.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Caitlin Charlton
회원 가입일: 03/22/15
756 평판
안내서 6개를 작성함
Baylor, Team 4-2, Williams Spring 2015 Baylor, Team 4-2, Williams Spring 2015 회원
BU-WILLIAMS-S15S4G2
3 회원들
안내서 12개를 작성함
2가이드 댓글
Where do I get the chip???
sean moore - 답글 공유
where do I get chip?
bugsyc26 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 35
전체 시간: 2,491
