주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement
필요한 것
    1. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Receiver: 1 단계, 이미지 1개 중 1개
      • Remove the 4 rubber tabs on the bottom side of the receiver.
      댓글 쓰기
    2. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: 2 단계, 이미지 1개 중 1개
      • Unscrew the four 12 mm screws on the bottom side of the receiver.
      • Use a Phillips #1 screwdriver for this step.
      댓글 쓰기
    3. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: 3 단계, 이미지 2개 중 1개 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: 3 단계, 이미지 2개 중 2개
      • Remove top casing from the receiver.
      • The receiver top casing is difficult to remove. Internal clasps may have to be broken in order to remove the top casing (this will not effect the device's function)
      댓글 쓰기
    1. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement, Receiver Wireless Audio Module Chip: 4 단계, 이미지 1개 중 1개
      • Unscrew the 10 mm screw holding the wireless audio module.
      댓글 쓰기
    2. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: 5 단계, 이미지 2개 중 1개 Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: 5 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Slide the black retaining flap securing the ribbon cable away from the white bar.
      • There should be only a small space between the white bar and black retaining flap.
      • You may want to use tweezers for this step.
      댓글 쓰기
    3. Rocketfish RF-WHTIB-A Receiver Wireless Audio Module Chip Replacement: 6 단계, 이미지 1개 중 1개
      • Using your fingers, slide the ribbon cable out from the under the black retaining flap to completely disconnect it from the device.
      댓글 쓰기
결론
To install the new wireless audio module chip, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Caitlin Charlton
회원 가입일: 03/22/15
756 평판
안내서 6개를 작성함
Baylor, Team 4-2, Williams Spring 2015 Baylor, Team 4-2, Williams Spring 2015 회원
BU-WILLIAMS-S15S4G2
3 회원들
안내서 18개를 작성함
1가이드 댓글
This is a very long time later, but where do you get the receiver chip??? Rocket fish doesn't support the product anymore
Michael Jay - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 31
전체 시간: 2,571
