주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement
필요한 것
    1. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement, How to Open the Rocketfish RF-WHTIB-A Sender: 1 단계, 이미지 1개 중 1개
      • Remove the four rubber tabs from the bottom of the sender.
      • Pull hard to peel off the rubber tabs, as they are attached with adhesive.
      댓글 쓰기
    2. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: 2 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to unscrew the four 12 mm screws on the bottom of the device.
      댓글 쓰기
    3. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: 3 단계, 이미지 2개 중 1개 Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: 3 단계, 이미지 2개 중 2개
      • Flip the device over and remove the top casing from the sender.
      댓글 쓰기
    1. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement, Sender Wireless Audio Module Chip: 4 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the wireless audio module chip.
      댓글 쓰기
    2. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: 5 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the motherboard.
      댓글 쓰기
    3. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: 6 단계, 이미지 1개 중 1개
      • Use a Phillips #1 screwdriver to unscrew the two 10 mm screws located on either side of the speakers.
      • Secure the front speaker input terminal to release the motherboard.
      댓글 쓰기
    4. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: 7 단계, 이미지 2개 중 1개 Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: 7 단계, 이미지 2개 중 2개
      • Using both thumbs, push the front speaker input terminal back towards the inside part of the device.
      댓글 쓰기
    5. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: 8 단계, 이미지 1개 중 1개
      • Flip over the motherboard and wireless audio module chip.
      댓글 쓰기
    6. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: 9 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Gently slide the black retaining flap back, securing the ribbon wire gently away from the white bar.
      • There should only be a small separation between the white bar and the black retaining flap.
      • Tweezers are recommended for this step.
      댓글 쓰기
    7. Rocketfish RF-WHTIB-A Sender Wireless Audio Module Chip Replacement: 10 단계, 이미지 1개 중 1개
      • Using your fingers, pull the ribbon wire out from the black retaining flap in order to completely disconnect the wireless audio module chip.
      댓글 쓰기
결론
To install the new wireless module chip, follow these instructions in reverse order.
Once the sender has been put back together, plug in the device and initiate the connection mode between the sender and receiver to ensure the new wireless module chip has been properly assembled.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Caitlin Charlton
회원 가입일: 03/22/15
756 평판
안내서 6개를 작성함
Baylor, Team 4-2, Williams Spring 2015 Baylor, Team 4-2, Williams Spring 2015 회원
BU-WILLIAMS-S15S4G2
3 회원들
안내서 18개를 작성함
3가이드 댓글
Does Rocketfish offer a replacement board?
Bob David - 답글 공유
“No Parts Required” is a joke . Where are the replacement boards available from?
Petie Martin - 답글 공유
I used the wrong ac adapter, which worked for a few weeks then the unit died and won't power on. Would anyone know what I should check out with the multi meter to see what's wrong and see if I can fix it? Thanks!
Adam Sawicki - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 37
전체 시간: 1,943
