주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Roku 3 Remote Control Buttons Replacement
필요한 것
  1. Roku 3 Remote Control Buttons Replacement, Remote Control Battery: 1 단계, 이미지 1개 중 1개
    • Flip the remote over so that the buttons are facing down and the end with the wrist strap is nearest your right hand.
    댓글 쓰기
  2. Roku 3 Remote Control Buttons Replacement: 2 단계, 이미지 2개 중 1개 Roku 3 Remote Control Buttons Replacement: 2 단계, 이미지 2개 중 2개
    • Press and hold the black tab above the battery compartment.
    • While holding down the tab with your left hand, slide down the battery compartment cover with your right hand to remove it.
    댓글 쓰기
  3. Roku 3 Remote Control Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the batteries by placing a finger on one end of the battery and pushing downward while pulling the battery out.
    댓글 쓰기
  4. Roku 3 Remote Control Buttons Replacement, Remote Control Buttons: 4 단계, 이미지 2개 중 1개 Roku 3 Remote Control Buttons Replacement, Remote Control Buttons: 4 단계, 이미지 2개 중 2개
    • Unscrew one 7 mm Phillips #0 screw from the center of the battery compartment.
    댓글 쓰기
  5. Roku 3 Remote Control Buttons Replacement: 5 단계, 이미지 2개 중 1개 Roku 3 Remote Control Buttons Replacement: 5 단계, 이미지 2개 중 2개
    • Gently pry open the remote using the plastic opening tool.
    댓글 쓰기
  6. Roku 3 Remote Control Buttons Replacement: 6 단계, 이미지 2개 중 1개 Roku 3 Remote Control Buttons Replacement: 6 단계, 이미지 2개 중 2개
    • Separate the top and bottom of the remote casing.
    • Gently place each half of the remote onto a table so that the exteriors are face down.
    • The remote buttons, sensors, and motherboard are not attached to anything inside the remote. Take apart the remote with caution to ensure these components do not accidentally fall out.
    댓글 쓰기
  7. Roku 3 Remote Control Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully flip over the front casing side of the remote so that the buttons drop onto the table.
    • If the buttons do not drop immediately, use your fingers to peal them off the front casing of the remote.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Isobelle Espiritu
회원 가입일: 10/06/16
591 평판
안내서 3개를 작성함
Cal Poly, Team 15-2, Livingston Fall 2016 Cal Poly, Team 15-2, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S15G2
3 회원들
안내서 6개를 작성함
4가이드 댓글
Do you have a source for getting replacement buttons? I have volume buttons that don't work and was hoping to fix them/ replace them. Thank you!
Patrick Canady - 답글 공유
Hi Patrick,
I literally just finished successfully fixing my volume-up button.
The replacement part number for the right microswitches is EVQ-P7J01P, available at Digi-Key:
https://www.digikey.com/product-detail/e...
Really inexpensive (around 30 cents each). Pro-tip - to help remove the old switch easily, cut it in half with sharp side-cutters.
Good luck!
Jeff T.
J Thomson - 답글 공유
Where can I find a component layout?
Rey De Castro - 답글 공유
Setuproku provides support for all roku related issue. This article help us to understand the Roku remote control.
setuproku code - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 43
전체 시간: 6,487
