주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Roku 4 Ethernet Port Replacement
필요한 것
    1. Roku 4 Ethernet Port Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
      • Place the Roku 4 face-down on a table. The rubber sticker should be facing you.
      댓글 쓰기
    2. Roku 4 Ethernet Port Replacement: 2 단계, 이미지 1개 중 1개
      • Starting at one corner of the device, pull the rubber sticker back toward the opposite corner of the device carefully to reveal the underlying screws.
      • Completely remove the rubber sticker to reveal the underlying screws on the device.
      • Place the rubber sticker facing up on the table to preserve its adhesiveness. It will be needed to reassemble the device.
      댓글 쓰기
    3. Roku 4 Ethernet Port Replacement: 3 단계, 이미지 1개 중 1개
      • Turn the Phillips PH1 screwdriver counterclockwise to unscrew all 4 of the 12.0 mm screws.
      • Store the screws in a safe place, such as on a magnetic project mat, so they do not get lost before reassembly.
      댓글 쓰기
    4. Roku 4 Ethernet Port Replacement: 4 단계, 이미지 2개 중 1개 Roku 4 Ethernet Port Replacement: 4 단계, 이미지 2개 중 2개
      • Turn the device over so you can see the "4" on the top cover.
      댓글 쓰기
    5. Roku 4 Ethernet Port Replacement: 5 단계, 이미지 2개 중 1개 Roku 4 Ethernet Port Replacement: 5 단계, 이미지 2개 중 2개
      • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device and create a gap.
      • Prying open the device is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
      댓글 쓰기
    6. Roku 4 Ethernet Port Replacement: 6 단계, 이미지 1개 중 1개
      • After you have created a gap large enough to fit your fingers between, gently lift up the top cover to open the device and reveal the motherboard.
      • The motherboard should still be attached to the underside of the top cover by a red wire, a blue wire, and a black wire.
      댓글 쓰기
    7. Roku 4 Ethernet Port Replacement: 7 단계, 이미지 3개 중 1개 Roku 4 Ethernet Port Replacement: 7 단계, 이미지 3개 중 2개 Roku 4 Ethernet Port Replacement: 7 단계, 이미지 3개 중 3개
      • To begin removing the motherboard from the plastic casing, pinch the black plastic clip and gently pull upward.
      • Once you feel the motherboard begin to loosen from the plastic casing, pull it upward to remove it completely.
      댓글 쓰기
    8. Roku 4 Ethernet Port Replacement: 8 단계, 이미지 3개 중 1개 Roku 4 Ethernet Port Replacement: 8 단계, 이미지 3개 중 2개 Roku 4 Ethernet Port Replacement: 8 단계, 이미지 3개 중 3개
      • Peel back the black adhesive strip that attaches the blue wire to the motherboard.
      • Repeat this step for the strip that attaches the black and red wires to the motherboard.
      댓글 쓰기
    9. Roku 4 Ethernet Port Replacement: 9 단계, 이미지 3개 중 1개 Roku 4 Ethernet Port Replacement: 9 단계, 이미지 3개 중 2개 Roku 4 Ethernet Port Replacement: 9 단계, 이미지 3개 중 3개
      • Using a soldering iron, desolder the blue, red, and black wires from the motherboard.
      • Consult iFixit's Soldering Skills guide to safely use the soldering iron.
      • The motherboard should now be completely disconnected from the top cover of the device.
      댓글 쓰기
    1. Roku 4 Ethernet Port Replacement, Ethernet Port: 10 단계, 이미지 1개 중 1개
      • Lay the motherboard facedown on the table so you can see the large black ethernet port with several gold connections below it.
      • Use a soldering iron to desolder each of the ethernet port's connections to the motherboard.
      • Consult iFixit's Soldering Skills guide to learn how to safely use the soldering iron.
      댓글 쓰기
    2. Roku 4 Ethernet Port Replacement: 11 단계, 이미지 1개 중 1개
      • Using your thumb and pointer finger, carefully pinch the Ethernet port and pull it to the right, away from the motherboard, to remove it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Hank Harrison
회원 가입일: 03/26/17
476 평판
안내서 3개를 작성함
Baylor, Team S5-G4, Williams Spring 2017 Baylor, Team S5-G4, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G4
3 회원들
안내서 8개를 작성함
3가이드 댓글
Is that the HDMI port
cruzanbay45 - 답글 공유
Is that the HDMI port on roku
cruzanbay45 - 답글 공유
where do you get the HDMI port for roku
mar plane - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 35
전체 시간: 1,619
