주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Roku 4 Remote Control Motherboard Replacement
필요한 것
    1. Roku 4 Remote Control Motherboard Replacement, Remote Control Motherboard: 1 단계, 이미지 1개 중 1개
      • Place the remote control facing down on the table, so that the buttons are facing downwards.
      댓글 쓰기
    2. Roku 4 Remote Control Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Roku 4 Remote Control Motherboard Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the battery compartment cover from the back of the remote by sliding it outwards. This should reveal the batteries.
      댓글 쓰기
    3. Roku 4 Remote Control Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Roku 4 Remote Control Motherboard Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the batteries from the battery compartment.
      댓글 쓰기
    4. Roku 4 Remote Control Motherboard Replacement: 4 단계, 이미지 1개 중 1개
      • Turn the Phillips PH0 screwdriver counterclockwise to carefully remove the 6.9 mm screw located between both battery compartments .
      댓글 쓰기
    5. Roku 4 Remote Control Motherboard Replacement: 5 단계, 이미지 1개 중 1개
      • Wedge a plastic opening tool into the seam between the top cover and bottom casing of the device to create a gap.
      • Prying open the remote is quite difficult and requires a large amount of force. Use caution to avoid breaking the device or hurting yourself.
      • Once you have created a gap large enough for your fingers to fit between, separate the top cover from the bottom plastic casing by pulling them apart gently.
      댓글 쓰기
    6. Roku 4 Remote Control Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Roku 4 Remote Control Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Roku 4 Remote Control Motherboard Replacement: 6 단계, 이미지 3개 중 3개
      • Using your right thumb, lift up on the left side of the motherboard to remove it from the bottom plastic casing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hank Harrison
회원 가입일: 03/26/17
476 평판
안내서 3개를 작성함
Baylor, Team S5-G4, Williams Spring 2017 Baylor, Team S5-G4, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G4
3 회원들
안내서 19개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 47
전체 시간: 2,141
