주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Roku Streaming Stick Motherboard Port replacement
필요한 것
    1. Roku Streaming Stick Motherboard Port replacement, Roku Streaming Stick Motherboard Port: 1 단계, 이미지 1개 중 1개
      • Grab the blue plastic opening tool to open the Roku Streaming Stick 3500R.
      댓글 쓰기
    2. Roku Streaming Stick Motherboard Port replacement: 2 단계, 이미지 2개 중 1개 Roku Streaming Stick Motherboard Port replacement: 2 단계, 이미지 2개 중 2개
      • Place the blue plastic opening tool into one of the cracks on the back of the Roku to pop open the Roku Streaming Stick 3500R. Be careful not to break anything while removing the back.
      댓글 쓰기
    3. Roku Streaming Stick Motherboard Port replacement: 3 단계, 이미지 1개 중 1개
      • Once you have removed the cover, you can now access the motherboard of the Roku Streaming Stick.
      댓글 쓰기
    4. Roku Streaming Stick Motherboard Port replacement: 4 단계, 이미지 2개 중 1개 Roku Streaming Stick Motherboard Port replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove the motherboard by grabbing a hold of the micro-usb port, or you can also use tweezers to grab a hold of it and pull it out. But be careful with where you grab the motherboard.
      댓글 쓰기
    5. Roku Streaming Stick Motherboard Port replacement: 5 단계, 이미지 3개 중 1개 Roku Streaming Stick Motherboard Port replacement: 5 단계, 이미지 3개 중 2개 Roku Streaming Stick Motherboard Port replacement: 5 단계, 이미지 3개 중 3개
      • Once you identify the HDMI port and the micro-usb port, you can investigate to see which port may be damaged.
      댓글 쓰기
    6. Roku Streaming Stick Motherboard Port replacement: 6 단계, 이미지 2개 중 1개 Roku Streaming Stick Motherboard Port replacement: 6 단계, 이미지 2개 중 2개
      • Once you have identified the problem you can then desolder the points at the HDMI as highlighted, or at the micro-usb ports.
      • If the soldering gun, or iron is set too high you then run the risk of destroying the motherboard altogether, or even damaging the wireless antennas.
      댓글 쓰기
결론
If the replacement of the motherboard does not work, another part may need to be replaced.
For reassembly, follow instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andy Miller
회원 가입일: 04/07/18
203 평판
안내서 1개를 작성함
IUPUI, Team S2-G2, Wilson Spring 2018 IUPUI, Team S2-G2, Wilson Spring 2018 회원
IUPUI-WILSON-S18S2G2
4 회원들
안내서 9개를 작성함
1가이드 댓글
Any idea where to buy a new hdmi port to solder on?
exxonchavez - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 44
전체 시간: 4,781
