주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Rowenta Focus Heating Element and Soleplate Replacement
필요한 것
    1. Rowenta Focus Heating Element and Soleplate Replacement, Power Assembly: 1 단계, 이미지 2개 중 1개 Rowenta Focus Heating Element and Soleplate Replacement, Power Assembly: 1 단계, 이미지 2개 중 2개
      • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
      • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
      댓글 쓰기
    2. Rowenta Focus Heating Element and Soleplate Replacement: 2 단계, 이미지 3개 중 1개 Rowenta Focus Heating Element and Soleplate Replacement: 2 단계, 이미지 3개 중 2개 Rowenta Focus Heating Element and Soleplate Replacement: 2 단계, 이미지 3개 중 3개
      • Pry the back cover of the iron off using a metal spudger.
      • Remove the back cover, exposing the wiring in the iron.
      댓글 쓰기
    3. Rowenta Focus Heating Element and Soleplate Replacement: 3 단계, 이미지 2개 중 1개 Rowenta Focus Heating Element and Soleplate Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
      • Leave the other cords attached to the main cord.
      댓글 쓰기
    4. Rowenta Focus Heating Element and Soleplate Replacement: 4 단계, 이미지 2개 중 1개 Rowenta Focus Heating Element and Soleplate Replacement: 4 단계, 이미지 2개 중 2개
      • Pull out the motherboard inside handle of iron.
      • Keep it attached to main power cord and other components.
      댓글 쓰기
    5. Rowenta Focus Heating Element and Soleplate Replacement: 5 단계, 이미지 3개 중 1개 Rowenta Focus Heating Element and Soleplate Replacement: 5 단계, 이미지 3개 중 2개 Rowenta Focus Heating Element and Soleplate Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
      댓글 쓰기
    1. Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: 6 단계, 이미지 3개 중 1개 Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: 6 단계, 이미지 3개 중 2개 Rowenta Focus Heating Element and Soleplate Replacement, Steam and Spray Button: 6 단계, 이미지 3개 중 3개
      • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
      • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
      • Lift out the piece.
      댓글 쓰기
    2. Rowenta Focus Heating Element and Soleplate Replacement: 7 단계, 이미지 3개 중 1개 Rowenta Focus Heating Element and Soleplate Replacement: 7 단계, 이미지 3개 중 2개 Rowenta Focus Heating Element and Soleplate Replacement: 7 단계, 이미지 3개 중 3개
      • Replace with an identical part by inserting it into the space.
      댓글 쓰기
    1. Rowenta Focus Heating Element and Soleplate Replacement, Heating Element/Soleplate: 8 단계, 이미지 2개 중 1개 Rowenta Focus Heating Element and Soleplate Replacement, Heating Element/Soleplate: 8 단계, 이미지 2개 중 2개
      • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
      댓글 쓰기
    2. Rowenta Focus Heating Element and Soleplate Replacement: 9 단계, 이미지 2개 중 1개 Rowenta Focus Heating Element and Soleplate Replacement: 9 단계, 이미지 2개 중 2개
      • Unhook the clips on the top of the metal piece.
      • Using the metal spudger, remove the metal piece on the tip of the iron.
      댓글 쓰기
    3. Rowenta Focus Heating Element and Soleplate Replacement: 10 단계, 이미지 2개 중 1개 Rowenta Focus Heating Element and Soleplate Replacement: 10 단계, 이미지 2개 중 2개
      • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
      댓글 쓰기
    4. Rowenta Focus Heating Element and Soleplate Replacement: 11 단계, 이미지 3개 중 1개 Rowenta Focus Heating Element and Soleplate Replacement: 11 단계, 이미지 3개 중 2개 Rowenta Focus Heating Element and Soleplate Replacement: 11 단계, 이미지 3개 중 3개
      • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
      댓글 쓰기
    5. Rowenta Focus Heating Element and Soleplate Replacement: 12 단계, 이미지 3개 중 1개 Rowenta Focus Heating Element and Soleplate Replacement: 12 단계, 이미지 3개 중 2개 Rowenta Focus Heating Element and Soleplate Replacement: 12 단계, 이미지 3개 중 3개
      • Lift the iron up using the handle to completely detach the soleplate.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Bella Navarro
회원 가입일: 09/03/21
462 평판
안내서 3개를 작성함
1가이드 댓글
hi how do i clean sole plate inside ??????????????????? wath sort of sealent do they use to seal it or where do you get it from????????????????
Willie Waldner - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 44
지난 30일: 194
전체 시간: 7,102
