주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Rowenta Focus Material Setting Knob Replacement
필요한 것
  1. Rowenta Focus Material Setting Knob Replacement, Power Assembly: 1 단계, 이미지 2개 중 1개 Rowenta Focus Material Setting Knob Replacement, Power Assembly: 1 단계, 이미지 2개 중 2개
    • Using a T20 screwdriver, remove the 20 mm screw on the back of the iron.
    • Unplug iron before removing cover and make sure the iron is cool before beginning the repair.
    댓글 쓰기
  2. Rowenta Focus Material Setting Knob Replacement: 2 단계, 이미지 3개 중 1개 Rowenta Focus Material Setting Knob Replacement: 2 단계, 이미지 3개 중 2개 Rowenta Focus Material Setting Knob Replacement: 2 단계, 이미지 3개 중 3개
    • Pry the back cover of the iron off using a metal spudger.
    • Remove the back cover, exposing the wiring in the iron.
    댓글 쓰기
  3. Rowenta Focus Material Setting Knob Replacement: 3 단계, 이미지 2개 중 1개 Rowenta Focus Material Setting Knob Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the frontmost (main) power cord to give access to inner wiring and accessories.
    • Leave the other cords attached to the main cord.
    댓글 쓰기
  4. Rowenta Focus Material Setting Knob Replacement: 4 단계, 이미지 2개 중 1개 Rowenta Focus Material Setting Knob Replacement: 4 단계, 이미지 2개 중 2개
    • Pull out the motherboard inside handle of iron.
    • Keep it attached to main power cord and other components.
    댓글 쓰기
  5. Rowenta Focus Material Setting Knob Replacement: 5 단계, 이미지 3개 중 1개 Rowenta Focus Material Setting Knob Replacement: 5 단계, 이미지 3개 중 2개 Rowenta Focus Material Setting Knob Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the 4-pronged adaptor from inside the iron by grabbing the black plastic piece and pulling straight out.
    댓글 쓰기
  6. Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: 6 단계, 이미지 3개 중 1개 Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: 6 단계, 이미지 3개 중 2개 Rowenta Focus Material Setting Knob Replacement, Steam and Spray Button: 6 단계, 이미지 3개 중 3개
    • Insert the metal spudger into the space between the spray/steam button piece and the rest of the iron.
    • Using the metal spudger for leverage, pry the piece away from the rest of the iron until it can be lifted out.
    • Lift out the piece.
    댓글 쓰기
  7. Rowenta Focus Material Setting Knob Replacement: 7 단계, 이미지 3개 중 1개 Rowenta Focus Material Setting Knob Replacement: 7 단계, 이미지 3개 중 2개 Rowenta Focus Material Setting Knob Replacement: 7 단계, 이미지 3개 중 3개
    • Replace with an identical part by inserting it into the space.
    댓글 쓰기
  8. Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: 8 단계, 이미지 2개 중 1개 Rowenta Focus Material Setting Knob Replacement, Heating Element/Soleplate: 8 단계, 이미지 2개 중 2개
    • Using the T20 screwdriver, remove the 20 mm screw that was under the steam and spray button.
    댓글 쓰기
  9. Rowenta Focus Material Setting Knob Replacement: 9 단계, 이미지 2개 중 1개 Rowenta Focus Material Setting Knob Replacement: 9 단계, 이미지 2개 중 2개
    • Unhook the clips on the top of the metal piece.
    • Using the metal spudger, remove the metal piece on the tip of the iron.
    댓글 쓰기
  10. Rowenta Focus Material Setting Knob Replacement: 10 단계, 이미지 2개 중 1개 Rowenta Focus Material Setting Knob Replacement: 10 단계, 이미지 2개 중 2개
    • Using the T20 screwdriver, remove the 20 mm screw that was under the metal piece on the tip of the iron.
    댓글 쓰기
  11. Rowenta Focus Material Setting Knob Replacement: 11 단계, 이미지 3개 중 1개 Rowenta Focus Material Setting Knob Replacement: 11 단계, 이미지 3개 중 2개 Rowenta Focus Material Setting Knob Replacement: 11 단계, 이미지 3개 중 3개
    • Using the T20 screwdriver, remove the two 20 mm screws on either side of the back of the iron.
    댓글 쓰기
  12. Rowenta Focus Material Setting Knob Replacement: 12 단계, 이미지 3개 중 1개 Rowenta Focus Material Setting Knob Replacement: 12 단계, 이미지 3개 중 2개 Rowenta Focus Material Setting Knob Replacement: 12 단계, 이미지 3개 중 3개
    • Lift the iron up using the handle to completely detach the soleplate.
    댓글 쓰기
  13. Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: 13 단계, 이미지 3개 중 1개 Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: 13 단계, 이미지 3개 중 2개 Rowenta Focus Material Setting Knob Replacement, Material Setting Knob: 13 단계, 이미지 3개 중 3개
    • Using the T20 screwdriver, remove both of the 20mm screws on the underside of the iron.
    댓글 쓰기
  14. Rowenta Focus Material Setting Knob Replacement: 14 단계, 이미지 2개 중 1개 Rowenta Focus Material Setting Knob Replacement: 14 단계, 이미지 2개 중 2개
    • Turn the iron over and pull the knob off.
    • Be careful not to tip the iron after removing the knob; there are small springs in the white piece underneath the knob.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Bella Navarro
회원 가입일: 09/03/21
462 평판
안내서 3개를 작성함
1가이드 댓글
Nice pics, came apart easily with this guide. Just need a note on the small ball bearing which I assume goes somewhere on the steam valve?
Step - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 15
지난 30일: 76
전체 시간: 2,330
