주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Rubber Watch Battery Replacement
필요한 것
    1. Rubber Watch Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Rubber Watch Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Begin by placing the watch on its backside.
      댓글 쓰기
    2. Rubber Watch Battery Replacement: 2 단계, 이미지 3개 중 1개 Rubber Watch Battery Replacement: 2 단계, 이미지 3개 중 2개 Rubber Watch Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Gently pull the top of the watch's back until the cap detaches, in a peeling motion.
      • Pull out the white cap and green chip once it is free.
      댓글 쓰기
    3. Rubber Watch Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Carefully puncture the plastic casing next to the battery on top of the green chip with the X-Acto knife and stop.
      • Be careful not to insert the X-Acto knife too downward into the battery.
      댓글 쓰기
    4. Rubber Watch Battery Replacement: 4 단계, 이미지 3개 중 1개 Rubber Watch Battery Replacement: 4 단계, 이미지 3개 중 2개 Rubber Watch Battery Replacement: 4 단계, 이미지 3개 중 3개
      • Flip the chip around to the front.
      • In a chiseling motion, make an incision on the front side above the battery to cut out a plastic casing.
      • Make sure to hold the knife away from the hands in a safe, stable grip.
      • Remove the cut plastic casing over the battery.
      • The plastic casing should come off like a cap.
      댓글 쓰기
    5. Rubber Watch Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Gently remove the battery with a spudger or a wooden coffee stick.
      • Using too much force may detach the tab holding the battery and break the watch.
      • Once free, remove the dead battery.
      댓글 쓰기
    6. Rubber Watch Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Insert the new battery.
      • Place the cut plastic cap casing over the chip and battery.
      댓글 쓰기
    7. Rubber Watch Battery Replacement: 7 단계, 이미지 3개 중 1개 Rubber Watch Battery Replacement: 7 단계, 이미지 3개 중 2개 Rubber Watch Battery Replacement: 7 단계, 이미지 3개 중 3개
      • Place the white cap over the green chip.
      • Insert the white cap and green chip into the back of the watch with the spudger or wooden coffee stick.
      • Turn over the watch and check the power.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Lee
회원 가입일: 04/28/17
110 평판
안내서 1개를 작성함
UC Davis, Team S2-G5, Cole Spring 2017 UC Davis, Team S2-G5, Cole Spring 2017 회원
UCD-COLE-S17S2G5
3 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 13
지난 30일: 77
전체 시간: 1,982
