주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ryobi D620H Trigger Replacement
필요한 것
    1. Ryobi D620H Trigger Replacement, Right Side Case Removal: 1 단계, 이미지 1개 중 1개
      • Turn the drill so that the screws face upwards.
      • Use the Torx T20 screwdriver to remove all nine screws.
      댓글 쓰기
    2. Ryobi D620H Trigger Replacement: 2 단계, 이미지 2개 중 1개 Ryobi D620H Trigger Replacement: 2 단계, 이미지 2개 중 2개
      • Insert the end of an opening tool between the right and left sides of the drill to pry the right side of the case.
      • Remove the right side case to expose the inside of the drill.
      댓글 쓰기
    1. Ryobi D620H Trigger Replacement, Power Cord: 3 단계, 이미지 1개 중 1개
      • The bend relief cover at the bottom of the handle.
      • Follow the wires coming out of the bend relief cover to the white power cord clamp with the two 14 mm black PH1 screws.
      댓글 쓰기
    2. Ryobi D620H Trigger Replacement: 4 단계, 이미지 2개 중 1개 Ryobi D620H Trigger Replacement: 4 단계, 이미지 2개 중 2개
      • Unscrew the two 14 mm PH1 screws holding the power cord wire in place.
      • Lift the switch box from its place gently.
      댓글 쓰기
    3. Ryobi D620H Trigger Replacement: 5 단계, 이미지 3개 중 1개 Ryobi D620H Trigger Replacement: 5 단계, 이미지 3개 중 2개 Ryobi D620H Trigger Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the two little screws holding the brass terminal lugs in place. Although it is not required, you can remove the screws completely if you find that doing so is more convenient.
      • Gently pull the white positive and black negative wires that are connected to the switch box.
      • Slide the bend relief guard off the cord towards the loose connections.
      댓글 쓰기
    1. Ryobi D620H Trigger Replacement, Trigger: 6 단계, 이미지 2개 중 1개 Ryobi D620H Trigger Replacement, Trigger: 6 단계, 이미지 2개 중 2개
      • Pull the four cables from the trigger terminals.
      댓글 쓰기
    2. Ryobi D620H Trigger Replacement: 7 단계, 이미지 1개 중 1개
      • Pull the two black wires that connect the motor from the switch box.
      • This may require some force.
      • When replacing the switch box these connections push into the new switch box.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Jacob da Ponte
회원 가입일: 10/30/23
469 평판
안내서 5개를 작성함
UMass Dartmouth, Team 1-2, Petersen Fall 2023 UMass Dartmouth, Team 1-2, Petersen Fall 2023 회원
UMASSD-PETERSEN-F23S1G2
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 26
전체 시간: 595
