주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ryobi P202 Motor Replacement
필요한 것
    1. Ryobi P202 Motor Replacement, Battery: 1 단계, 이미지 3개 중 1개 Ryobi P202 Motor Replacement, Battery: 1 단계, 이미지 3개 중 2개 Ryobi P202 Motor Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • The battery can shock you. Only touch plastic, non-conductive components.
      • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
      댓글 쓰기
    1. Ryobi P202 Motor Replacement, Right Side Case: 2 단계, 이미지 2개 중 1개 Ryobi P202 Motor Replacement, Right Side Case: 2 단계, 이미지 2개 중 2개
      • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
      댓글 쓰기
    2. Ryobi P202 Motor Replacement: 3 단계, 이미지 2개 중 1개 Ryobi P202 Motor Replacement: 3 단계, 이미지 2개 중 2개
      • Gently lift the casing from the drill body.
      • Take the casing completely off the drill body to gain access to the interior of the drill.
      • The Ryobi P202 casing has Part #: 200690001
      댓글 쓰기
    1. Ryobi P202 Motor Replacement, Magnetic Tray: 4 단계, 이미지 2개 중 1개 Ryobi P202 Motor Replacement, Magnetic Tray: 4 단계, 이미지 2개 중 2개
      • Gently lift the magnetic tray from the bottom of the drill body.
      • The magnet is Part #: 303001015
      댓글 쓰기
    1. Ryobi P202 Motor Replacement, Bit Storage Clip: 5 단계, 이미지 2개 중 1개 Ryobi P202 Motor Replacement, Bit Storage Clip: 5 단계, 이미지 2개 중 2개
      • Grip the bit-clip and gently lift up to remove it from the case.
      • The bit-clip is Part #: 630206007
      댓글 쓰기
    1. Ryobi P202 Motor Replacement, Level Gauge: 6 단계, 이미지 3개 중 1개 Ryobi P202 Motor Replacement, Level Gauge: 6 단계, 이미지 3개 중 2개 Ryobi P202 Motor Replacement, Level Gauge: 6 단계, 이미지 3개 중 3개
      • Rotate the Drill 180 degrees so that the top is facing you.
      • Lift the level gauge out from the top corner of the drill.
      • The level gauge is Part #: 3000909
      댓글 쓰기
    1. Ryobi P202 Motor Replacement, Gear Select Switch: 7 단계, 이미지 2개 중 1개 Ryobi P202 Motor Replacement, Gear Select Switch: 7 단계, 이미지 2개 중 2개
      • Lift the gear switch upwards from the top of the drill head.
      • The gear switch is Part #: 341098001
      댓글 쓰기
    1. Ryobi P202 Motor Replacement, Battery Contacts: 8 단계, 이미지 2개 중 1개 Ryobi P202 Motor Replacement, Battery Contacts: 8 단계, 이미지 2개 중 2개
      • Grip the battery clip and pull straight up to remove the metal battery contacts.
      • You can now clean the metal battery contacts with isopropyl alcohol.
      댓글 쓰기
    1. Ryobi P202 Motor Replacement, Trigger Assembly: 9 단계, 이미지 2개 중 1개 Ryobi P202 Motor Replacement, Trigger Assembly: 9 단계, 이미지 2개 중 2개
      • Holding the direction select switch in place, grip both sides of the trigger assembly and lift it up and towards the base of the drill.
      댓글 쓰기
    2. Ryobi P202 Motor Replacement: 10 단계, 이미지 2개 중 1개 Ryobi P202 Motor Replacement: 10 단계, 이미지 2개 중 2개
      • To separate the trigger assembly from the motor, use a soldering iron to melt the solder and pull gently on the red and black wires from the trigger.
      • Heating the solder may melt the plastic packaging. Prior experience with soldering is required.
      • The trigger assembly is Part #: 270001392
      댓글 쓰기
    1. Ryobi P202 Motor Replacement, Motor: 11 단계, 이미지 2개 중 1개 Ryobi P202 Motor Replacement, Motor: 11 단계, 이미지 2개 중 2개
      • Gripping the rear of the motor and the chuck, lift up.
      • There are two copper springs that are attached to the front of the chuck. They may fall off when lifting the chuck, so be careful when doing so.
      댓글 쓰기
    2. Ryobi P202 Motor Replacement: 12 단계, 이미지 2개 중 1개 Ryobi P202 Motor Replacement: 12 단계, 이미지 2개 중 2개
      • Remove the copper springs. There are two on the either sides of the chuck and are loosely placed in the chuck's grooves.
      • These springs are small and may fall off when you lift the motor up. Take note of the springs when doing so.
      댓글 쓰기
    3. Ryobi P202 Motor Replacement: 13 단계, 이미지 2개 중 1개 Ryobi P202 Motor Replacement: 13 단계, 이미지 2개 중 2개
      • Lift up on the direction toggle to remove it from the case.
      댓글 쓰기
    4. Ryobi P202 Motor Replacement: 14 단계, 이미지 3개 중 1개 Ryobi P202 Motor Replacement: 14 단계, 이미지 3개 중 2개 Ryobi P202 Motor Replacement: 14 단계, 이미지 3개 중 3개
      • Hold the chuck and twist the motor clockwise and then pull apart to separate the motor from the chuck.
      • The chuck has a loose black washer that holds five gears in place. Be careful not to separate the washer.
      • When reassembling the chuck and motor, take note that the red wire in the back of the motor is farthest from the top of the assembly. In other words, the red wire should be closest to the trigger.
      댓글 쓰기
    5. Ryobi P202 Motor Replacement: 15 단계, 이미지 2개 중 1개 Ryobi P202 Motor Replacement: 15 단계, 이미지 2개 중 2개
      • Unscrew the two 10mm Philips #1 screws to remove the plastic spacer. Be careful not to lose the metal ring washers that come with the screws.
      댓글 쓰기
    6. Ryobi P202 Motor Replacement: 16 단계, 이미지 3개 중 1개 Ryobi P202 Motor Replacement: 16 단계, 이미지 3개 중 2개 Ryobi P202 Motor Replacement: 16 단계, 이미지 3개 중 3개
      • Remove the plastic spacer by lifting it straight up.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Joseph Eckstein
회원 가입일: 04/07/15
1,596 평판
안내서 9개를 작성함
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 회원
CPSU-FORTE-S15S17G6
4 회원들
안내서 10개를 작성함
1가이드 댓글
How can I order the copper motor for P202?
Wilfredo. A. Burgos - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 43
전체 시간: 12,775
