주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ryobi P202 Trigger Assembly Replacement
필요한 것
    1. Ryobi P202 Trigger Assembly Replacement, Battery: 1 단계, 이미지 3개 중 1개 Ryobi P202 Trigger Assembly Replacement, Battery: 1 단계, 이미지 3개 중 2개 Ryobi P202 Trigger Assembly Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • The battery can shock you. Only touch plastic, non-conductive components.
      • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
      댓글 쓰기
    1. Ryobi P202 Trigger Assembly Replacement, Right Side Case: 2 단계, 이미지 2개 중 1개 Ryobi P202 Trigger Assembly Replacement, Right Side Case: 2 단계, 이미지 2개 중 2개
      • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
      댓글 쓰기
    2. Ryobi P202 Trigger Assembly Replacement: 3 단계, 이미지 2개 중 1개 Ryobi P202 Trigger Assembly Replacement: 3 단계, 이미지 2개 중 2개
      • Gently lift the casing from the drill body.
      • Take the casing completely off the drill body to gain access to the interior of the drill.
      • The Ryobi P202 casing has Part #: 200690001
      댓글 쓰기
    1. Ryobi P202 Trigger Assembly Replacement, Battery Contacts: 4 단계, 이미지 2개 중 1개 Ryobi P202 Trigger Assembly Replacement, Battery Contacts: 4 단계, 이미지 2개 중 2개
      • Grip the battery clip and pull straight up to remove the metal battery contacts.
      • You can now clean the metal battery contacts with isopropyl alcohol.
      댓글 쓰기
    1. Ryobi P202 Trigger Assembly Replacement, Trigger Assembly: 5 단계, 이미지 2개 중 1개 Ryobi P202 Trigger Assembly Replacement, Trigger Assembly: 5 단계, 이미지 2개 중 2개
      • Holding the direction select switch in place, grip both sides of the trigger assembly and lift it up and towards the base of the drill.
      댓글 쓰기
    2. Ryobi P202 Trigger Assembly Replacement: 6 단계, 이미지 2개 중 1개 Ryobi P202 Trigger Assembly Replacement: 6 단계, 이미지 2개 중 2개
      • To separate the trigger assembly from the motor, use a soldering iron to melt the solder and pull gently on the red and black wires from the trigger.
      • Heating the solder may melt the plastic packaging. Prior experience with soldering is required.
      • The trigger assembly is Part #: 270001392
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. You will need solder to reattach the wires to the trigger assembly.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Joseph Eckstein
회원 가입일: 04/07/15
1,596 평판
안내서 9개를 작성함
Cal Poly, Team 17-6, Forte Spring 2015 Cal Poly, Team 17-6, Forte Spring 2015 회원
CPSU-FORTE-S15S17G6
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 55
전체 시간: 5,751
