주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ryobi P235 Direction of Rotation Selector Replacement
필요한 것
    1. Ryobi P235 Direction of Rotation Selector Replacement, Battery: 1 단계, 이미지 2개 중 1개 Ryobi P235 Direction of Rotation Selector Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Push in both push tabs on the battery at the same time.
      • They are located below the green housing and are in the middle on both sides of the battery.
      댓글 쓰기
    2. Ryobi P235 Direction of Rotation Selector Replacement: 2 단계, 이미지 2개 중 1개 Ryobi P235 Direction of Rotation Selector Replacement: 2 단계, 이미지 2개 중 2개
      • Pull the battery away from the drill housing while holding in both tabs.
      댓글 쓰기
    1. Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: 3 단계, 이미지 2개 중 1개 Ryobi P235 Direction of Rotation Selector Replacement, Direction of Rotation Selector: 3 단계, 이미지 2개 중 2개
      • Use a Phillips #2 screwdriver to remove the eight 16 mm screws that secure the housing.
      댓글 쓰기
    2. Ryobi P235 Direction of Rotation Selector Replacement: 4 단계, 이미지 2개 중 1개 Ryobi P235 Direction of Rotation Selector Replacement: 4 단계, 이미지 2개 중 2개
      • Use a T20 Torx screwdriver to remove the four 25.4 mm screws that secure the front of the housing.
      댓글 쓰기
    3. Ryobi P235 Direction of Rotation Selector Replacement: 5 단계, 이미지 2개 중 1개 Ryobi P235 Direction of Rotation Selector Replacement: 5 단계, 이미지 2개 중 2개
      • Open the housing with the data label facing up.
      댓글 쓰기
    4. Ryobi P235 Direction of Rotation Selector Replacement: 6 단계, 이미지 2개 중 1개 Ryobi P235 Direction of Rotation Selector Replacement: 6 단계, 이미지 2개 중 2개
      • Lift the internal components out of the housing.
      댓글 쓰기
    5. Ryobi P235 Direction of Rotation Selector Replacement: 7 단계, 이미지 2개 중 1개 Ryobi P235 Direction of Rotation Selector Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the gray plastic forward/reverse selector.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Justin Godleski
회원 가입일: 03/19/18
319 평판
안내서 1개를 작성함
UMass Dartmouth, Team S4-G2, Saloman Fall 2019 UMass Dartmouth, Team S4-G2, Saloman Fall 2019 회원
UMASSD-SALOMAN-F19S4G2
3 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 39
전체 시간: 1,337
