주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ryobi RJ1861V Motor Replacement
필요한 것
    1. Ryobi RJ1861V Motor Replacement, Saw Bar Assembly: 1 단계, 이미지 1개 중 1개
      • Use a Torx T5 screwdriver to remove the single 8 mm screw securing the shoe.
      댓글 쓰기
    2. Ryobi RJ1861V Motor Replacement: 2 단계, 이미지 2개 중 1개 Ryobi RJ1861V Motor Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the rubber sleeve.
      • You may have to use some force as it has a tight fit.
      댓글 쓰기
    3. Ryobi RJ1861V Motor Replacement: 3 단계, 이미지 1개 중 1개
      • Use a Torx T5 screwdriver to remove the six screws on the underside of the device.
      댓글 쓰기
    4. Ryobi RJ1861V Motor Replacement: 4 단계, 이미지 1개 중 1개
      • Use a Torx T5 screwdriver to remove the four screws on the top of the gear case.
      • There are two screws on each side of the device.
      댓글 쓰기
    5. Ryobi RJ1861V Motor Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the backside panel.
      댓글 쓰기
    6. Ryobi RJ1861V Motor Replacement: 6 단계, 이미지 1개 중 1개
      • Unscrew the four T5 Torx screws that hold the assembly bar in place.
      댓글 쓰기
    7. Ryobi RJ1861V Motor Replacement: 7 단계, 이미지 1개 중 1개
      • Lift the assembly bar up and out of the chassis.
      댓글 쓰기
    1. Ryobi RJ1861V Motor Replacement, Assembly Bar Bearing: 8 단계, 이미지 1개 중 1개
      • Begin with the top of the device facing up.
      댓글 쓰기
    2. Ryobi RJ1861V Motor Replacement: 9 단계, 이미지 1개 중 1개
      • Insert needle nose pliers to remove the retaining pin at the top of the bearing.
      댓글 쓰기
    3. Ryobi RJ1861V Motor Replacement: 10 단계, 이미지 1개 중 1개
      • Once the retaining pin has been removed, pull off the damaged bearing and insert a new one.
      댓글 쓰기
    1. Ryobi RJ1861V Motor Replacement, Motor: 11 단계, 이미지 1개 중 1개
      • The motor is divided into two sections, one attached to the gear case and one attached to the handle.
      • This arrow indicates the section attached to the gear case.
      • This arrow indicates the section attached to the handle.
      댓글 쓰기
    2. Ryobi RJ1861V Motor Replacement: 12 단계, 이미지 3개 중 1개 Ryobi RJ1861V Motor Replacement: 12 단계, 이미지 3개 중 2개 Ryobi RJ1861V Motor Replacement: 12 단계, 이미지 3개 중 3개
      • Use a Torx T5 screwdriver to remove the four screws attaching the motor to the gear case.
      댓글 쓰기
    3. Ryobi RJ1861V Motor Replacement: 13 단계, 이미지 1개 중 1개
      • Use a Torx T5 screwdriver to remove the two screws inside the motor housing of the handle.
      댓글 쓰기
    4. Ryobi RJ1861V Motor Replacement: 14 단계, 이미지 2개 중 1개 Ryobi RJ1861V Motor Replacement: 14 단계, 이미지 2개 중 2개
      • Remove the four screws on the back of the housing with a Torx T5 screwdriver.
      • Flip the housing over and pull the motor up and out of the housing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Adrian Williams
회원 가입일: 04/08/19
183 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 40
전체 시간: 754
