주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SEGA Genesis Flashback Controller Buttons Replacement
필요한 것
  1. SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: 1 단계, 이미지 3개 중 1개 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: 1 단계, 이미지 3개 중 2개 SEGA Genesis Flashback Controller Buttons Replacement, Controller Back Cover: 1 단계, 이미지 3개 중 3개
    • Hold the controller with the bottom plate facing up, and gently remove the top plate that is connected to the motherboard of the controller. Set the top plate aside.
    • Remove the screws on the back of the controller with the Phillips #000 screwdriver.
    • Be sure to separate the two plates with the bottom facing up, to keep the buttons from falling out.
    댓글 쓰기
  2. SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: 2 단계, 이미지 2개 중 1개 SEGA Genesis Flashback Controller Buttons Replacement, Controller Buttons: 2 단계, 이미지 2개 중 2개
    • CAUTION: Pull gently on the rubber membranes to avoid tearing .
    • Use two fingers to remove each rubber membrane that rests on top of the buttons.
    댓글 쓰기
  3. SEGA Genesis Flashback Controller Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Pop the button out from the front side of the controller.
    • Pull the button out from the backside using the other hand.
    • All removable buttons can only be placed in their respective holes due to unique groove patterns on the buttons. Keep in mind where each button belongs to make re-assembly easier.
    • All buttons can be removed except for the D-Pad.
    댓글 쓰기
  4. SEGA Genesis Flashback Controller Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • Repeat Step 3 for the remaining buttons.
    • The button should pop out seamlessly and placed to the side.
    • Repeat the prior steps in order to remove all the buttons. Set them aside in an order you will remember to where they belong.
    댓글 쓰기
결론
After completing step 4 you will need to re-assemble your controller. Do this by starting from step 2 and work backwards. Take your e-waste to an R2 or e-Stewards certified recycler.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Viet Nguyen
회원 가입일: 04/17/18
220 평판
안내서 2개를 작성함
Cal Poly, Team S24-G12, Maness Spring 2018 Cal Poly, Team S24-G12, Maness Spring 2018 회원
CPSU-MANESS-S18S24G12
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 50
전체 시간: 2,239
