주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SG 552-1 Commando Gearbox Replacement
필요한 것
    1. SG 552-1 Commando Gearbox Replacement, Gearbox: 1 단계, 이미지 2개 중 1개 SG 552-1 Commando Gearbox Replacement, Gearbox: 1 단계, 이미지 2개 중 2개
      • Using a flathead screwdriver, remove the pin holding the hand guard in place.
      • To remove this, turn the pin clockwise and push it through at the same time.
      • Remove the hand guard.
      댓글 쓰기
    2. SG 552-1 Commando Gearbox Replacement: 2 단계, 이미지 2개 중 1개 SG 552-1 Commando Gearbox Replacement: 2 단계, 이미지 2개 중 2개
      • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun.
      • There should be four total.
      댓글 쓰기
    3. SG 552-1 Commando Gearbox Replacement: 3 단계, 이미지 2개 중 1개 SG 552-1 Commando Gearbox Replacement: 3 단계, 이미지 2개 중 2개
      • Turn the gun over so that you are facing the bottom of the gun.
      • Using a Phillips #1 screwdriver, remove the following screws:
      • Remove the 8mm screw that is located directly underneath the cocking lever.
      • Remove the 8mm screw located beside the screw you just removed.
      댓글 쓰기
    4. SG 552-1 Commando Gearbox Replacement: 4 단계, 이미지 2개 중 1개 SG 552-1 Commando Gearbox Replacement: 4 단계, 이미지 2개 중 2개
      • Carefully tug on the tip of the gun and pull the barrel and its cover out.
      댓글 쓰기
    5. SG 552-1 Commando Gearbox Replacement: 5 단계, 이미지 3개 중 1개 SG 552-1 Commando Gearbox Replacement: 5 단계, 이미지 3개 중 2개 SG 552-1 Commando Gearbox Replacement: 5 단계, 이미지 3개 중 3개
      • Locate the hand grip.
      • Using a Phillips #0 screwdriver, remove the two 6mm screws at the bottom of the hand grip.
      • Slide the cover off.
      댓글 쓰기
    6. SG 552-1 Commando Gearbox Replacement: 6 단계, 이미지 2개 중 1개 SG 552-1 Commando Gearbox Replacement: 6 단계, 이미지 2개 중 2개
      • Pull the motor out of the hand grip.
      • Using a Phillips #1 screwdriver, remove the two 5mm screws inside of the hand grip.
      댓글 쓰기
    7. SG 552-1 Commando Gearbox Replacement: 7 단계, 이미지 2개 중 1개 SG 552-1 Commando Gearbox Replacement: 7 단계, 이미지 2개 중 2개
      • Locate the pin holding the folding stock in place.
      • Using an allen wrench or something small, carefully push the pin out.
      댓글 쓰기
    8. SG 552-1 Commando Gearbox Replacement: 8 단계, 이미지 2개 중 1개 SG 552-1 Commando Gearbox Replacement: 8 단계, 이미지 2개 중 2개
      • Using a Phillips #1 screwdriver, remove the 20mm screw behind the folding stock and above the gearbox.
      • Remove the cover that was held on by the screw.
      댓글 쓰기
    9. SG 552-1 Commando Gearbox Replacement: 9 단계, 이미지 3개 중 1개 SG 552-1 Commando Gearbox Replacement: 9 단계, 이미지 3개 중 2개 SG 552-1 Commando Gearbox Replacement: 9 단계, 이미지 3개 중 3개
      • Using a flathead screwdriver, remove the two 5mm screws beside the safety switch on both sides of the gun.
      • Slide off the piece that was held on by those screws.
      댓글 쓰기
    10. SG 552-1 Commando Gearbox Replacement: 10 단계, 이미지 2개 중 1개 SG 552-1 Commando Gearbox Replacement: 10 단계, 이미지 2개 중 2개
      • Using a small allen wrench, carefully unscrew the screws holding the safety switch in place on both sides of the gun.
      • The screws do not have to be taken out all the way, just slightly loosen them until you are able to pull the switch off.
      댓글 쓰기
    11. SG 552-1 Commando Gearbox Replacement: 11 단계, 이미지 2개 중 1개 SG 552-1 Commando Gearbox Replacement: 11 단계, 이미지 2개 중 2개
      • Using a Phillips #0 screwdriver, remove the two 6mm screws that were underneath the safety switch on both sides of the gun.
      • Carefully remove the pieces that were held on by the screws.
      댓글 쓰기
    12. SG 552-1 Commando Gearbox Replacement: 12 단계, 이미지 3개 중 1개 SG 552-1 Commando Gearbox Replacement: 12 단계, 이미지 3개 중 2개 SG 552-1 Commando Gearbox Replacement: 12 단계, 이미지 3개 중 3개
      • Pull apart the cover when pulling the gearbox out.
      • Pull the gearbox out.
      • The gears will fall out when taking the gearbox out. Careful not to lose them.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Amanda Toan
회원 가입일: 10/05/12
292 평판
안내서 1개를 작성함
Cal Poly, Team 18-41, Regan Fall 2012 Cal Poly, Team 18-41, Regan Fall 2012 회원
CPSU-REGAN-F12S18G41
6 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 29
전체 시간: 3,020
