주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SG 552-1 Commando Spring Replacement
필요한 것
  1. SG 552-1 Commando Spring Replacement, Gearbox: 1 단계, 이미지 2개 중 1개 SG 552-1 Commando Spring Replacement, Gearbox: 1 단계, 이미지 2개 중 2개
    • Using a flathead screwdriver, remove the pin holding the hand guard in place.
    • To remove this, turn the pin clockwise and push it through at the same time.
    • Remove the hand guard.
    댓글 쓰기
  2. SG 552-1 Commando Spring Replacement: 2 단계, 이미지 2개 중 1개 SG 552-1 Commando Spring Replacement: 2 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the two 8mm screws above the hand guard on both sides of the gun.
    • There should be four total.
    댓글 쓰기
  3. SG 552-1 Commando Spring Replacement: 3 단계, 이미지 2개 중 1개 SG 552-1 Commando Spring Replacement: 3 단계, 이미지 2개 중 2개
    • Turn the gun over so that you are facing the bottom of the gun.
    • Using a Phillips #1 screwdriver, remove the following screws:
    • Remove the 8mm screw that is located directly underneath the cocking lever.
    • Remove the 8mm screw located beside the screw you just removed.
    댓글 쓰기
  4. SG 552-1 Commando Spring Replacement: 4 단계, 이미지 2개 중 1개 SG 552-1 Commando Spring Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully tug on the tip of the gun and pull the barrel and its cover out.
    댓글 쓰기
  5. SG 552-1 Commando Spring Replacement: 5 단계, 이미지 3개 중 1개 SG 552-1 Commando Spring Replacement: 5 단계, 이미지 3개 중 2개 SG 552-1 Commando Spring Replacement: 5 단계, 이미지 3개 중 3개
    • Locate the hand grip.
    • Using a Phillips #0 screwdriver, remove the two 6mm screws at the bottom of the hand grip.
    • Slide the cover off.
    댓글 쓰기
  6. SG 552-1 Commando Spring Replacement: 6 단계, 이미지 2개 중 1개 SG 552-1 Commando Spring Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the motor out of the hand grip.
    • Using a Phillips #1 screwdriver, remove the two 5mm screws inside of the hand grip.
    댓글 쓰기
  7. SG 552-1 Commando Spring Replacement: 7 단계, 이미지 2개 중 1개 SG 552-1 Commando Spring Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the pin holding the folding stock in place.
    • Using an allen wrench or something small, carefully push the pin out.
    댓글 쓰기
  8. SG 552-1 Commando Spring Replacement: 8 단계, 이미지 2개 중 1개 SG 552-1 Commando Spring Replacement: 8 단계, 이미지 2개 중 2개
    • Using a Phillips #1 screwdriver, remove the 20mm screw behind the folding stock and above the gearbox.
    • Remove the cover that was held on by the screw.
    댓글 쓰기
  9. SG 552-1 Commando Spring Replacement: 9 단계, 이미지 3개 중 1개 SG 552-1 Commando Spring Replacement: 9 단계, 이미지 3개 중 2개 SG 552-1 Commando Spring Replacement: 9 단계, 이미지 3개 중 3개
    • Using a flathead screwdriver, remove the two 5mm screws beside the safety switch on both sides of the gun.
    • Slide off the piece that was held on by those screws.
    댓글 쓰기
  10. SG 552-1 Commando Spring Replacement: 10 단계, 이미지 2개 중 1개 SG 552-1 Commando Spring Replacement: 10 단계, 이미지 2개 중 2개
    • Using a small allen wrench, carefully unscrew the screws holding the safety switch in place on both sides of the gun.
    • The screws do not have to be taken out all the way, just slightly loosen them until you are able to pull the switch off.
    댓글 쓰기
  11. SG 552-1 Commando Spring Replacement: 11 단계, 이미지 2개 중 1개 SG 552-1 Commando Spring Replacement: 11 단계, 이미지 2개 중 2개
    • Using a Phillips #0 screwdriver, remove the two 6mm screws that were underneath the safety switch on both sides of the gun.
    • Carefully remove the pieces that were held on by the screws.
    댓글 쓰기
  12. SG 552-1 Commando Spring Replacement: 12 단계, 이미지 3개 중 1개 SG 552-1 Commando Spring Replacement: 12 단계, 이미지 3개 중 2개 SG 552-1 Commando Spring Replacement: 12 단계, 이미지 3개 중 3개
    • Pull apart the cover when pulling the gearbox out.
    • Pull the gearbox out.
    • The gears will fall out when taking the gearbox out. Careful not to lose them.
    댓글 쓰기
  13. SG 552-1 Commando Spring Replacement, Spring: 13 단계, 이미지 2개 중 1개 SG 552-1 Commando Spring Replacement, Spring: 13 단계, 이미지 2개 중 2개
    • Remove these four 15mm screws.
    • Remove this single 8mm screw.
    • Using a Phillips #0 screwdriver, remove the following screws:
    • Remove this single 3mm screw.
    • Remove this single 14mm screw.
    • Detach the pieces unscrewed from the gearbox.
    댓글 쓰기
  14. SG 552-1 Commando Spring Replacement: 14 단계, 이미지 2개 중 1개 SG 552-1 Commando Spring Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the piece covering the trigger.
    • Remove the safety piece.
    • Using a Phillips #1 screwdriver, remove the 18mm screw beside the trigger.
    댓글 쓰기
  15. SG 552-1 Commando Spring Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the metal piece.
    • Removing this piece will permanently damage the metal piece.
    댓글 쓰기
  16. SG 552-1 Commando Spring Replacement: 16 단계, 이미지 3개 중 1개 SG 552-1 Commando Spring Replacement: 16 단계, 이미지 3개 중 2개 SG 552-1 Commando Spring Replacement: 16 단계, 이미지 3개 중 3개
    • Remove the cover and pull out the spring.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
Anika Morris
회원 가입일: 10/05/12
1 평판
안내서 4개를 작성함
Cal Poly, Team 18-41, Regan Fall 2012 Cal Poly, Team 18-41, Regan Fall 2012 회원
CPSU-REGAN-F12S18G41
6 회원들
안내서 6개를 작성함
1가이드 댓글
When i read step 15 it seems impossible to up/downgrade spring without damaging the gun permanently??
Marco den Hartog - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 8
지난 30일: 50
전체 시간: 2,290
