주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SGH-A117 keypad replacement
필요한 것
  1. SGH-A117 keypad replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the battery by pressing the battery lock down and slide the battery cover away.
    댓글 쓰기
  2. SGH-A117 keypad replacement: 2 단계, 이미지 1개 중 1개
    • Lift the bottom of the battery and then move it up and away.
    댓글 쓰기
  3. SGH-A117 keypad replacement, Motherboard: 3 단계, 이미지 1개 중 1개
    • Locate the 4 screws holes on the phone and remove them with the #000 Philips Head screwdriver. (See red circles)
    댓글 쓰기
  4. SGH-A117 keypad replacement: 4 단계, 이미지 1개 중 1개
    • Using the plastic opening tool, gently pry open the back piece of the phone.
    • Make sure to do this very carefully, as the back part of the phone is very thin and fragile.
    댓글 쓰기
  5. SGH-A117 keypad replacement: 5 단계, 이미지 1개 중 1개
    • Use the metal prying tool to gently flick up the rectangular connector. (Because this device is on the smaller side, the rectangular connector may only need a simple flick with the prying tool)
    • Simply flick the rectangular connector up from its socket. (Highlighted by the red square)
    댓글 쓰기
  6. SGH-A117 keypad replacement: 6 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to gently pry up the motherboard.
    • You may need to pry the motherboard up from several angles in order to remove it.
    댓글 쓰기
  7. SGH-A117 keypad replacement, Keypad: 7 단계, 이미지 1개 중 1개
    • After the connector has been removed you will gently pull off the mother board, which will reveal the rubber keypad.
    댓글 쓰기
  8. SGH-A117 keypad replacement: 8 단계, 이미지 1개 중 1개
    • Replace the faulty keypad, and reassemble the phone.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Stephanie Isaac
회원 가입일: 09/11/15
431 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 35
전체 시간: 552
