주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SIM Card Slot Repair
필요한 것
    1. SIM Card Slot Repair, SIM Card Slot Repair: 1 단계, 이미지 3개 중 1개 SIM Card Slot Repair, SIM Card Slot Repair: 1 단계, 이미지 3개 중 2개 SIM Card Slot Repair, SIM Card Slot Repair: 1 단계, 이미지 3개 중 3개
      • Start by getting your work space set up and clear of clutter.
      • Remove the back of the phone.
      • Remove the battery and set it aside.
      댓글 쓰기
    2. SIM Card Slot Repair: 2 단계, 이미지 2개 중 1개 SIM Card Slot Repair: 2 단계, 이미지 2개 중 2개
      • Remove the six 2.3mm screws with a "T5" Screwdriver.
      • Remove the 2 additional 2.3mm screws from the side opposite the volume and power button.
      • When you open the back of the phone the camera and speaker will be attached to the part that you are removing.
      댓글 쓰기
    3. SIM Card Slot Repair: 3 단계, 이미지 3개 중 1개 SIM Card Slot Repair: 3 단계, 이미지 3개 중 2개 SIM Card Slot Repair: 3 단계, 이미지 3개 중 3개
      • Inspect the sim slot to find where the factory solder might be broken.
      • Once found dip the soldering gun in the flux to prevent the solder sticking to the gun.
      • Use the 60/40 lead solder to repair the damaged spot on the sim slot.
      • Do NOT allow the solder to touch any other connections as it could cause the device to short out or no function properly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cyndal Burns
회원 가입일: 06/02/17
179 평판
안내서 1개를 작성함
1가이드 댓글
I recently purchased a custom built phone which has the best parts of Android with the IMAX 13 camera my SIM tray broke and I can't seem to find anyone that has or knows which kind goes here is there any way you could help me
Bryan S. - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 30
지난 30일: 116
전체 시간: 15,656
