주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SKYTEX SP1020 Battery Replacement
필요한 것
    1. SKYTEX SP1020 Battery Replacement, Rear Case: 1 단계, 이미지 2개 중 1개 SKYTEX SP1020 Battery Replacement, Rear Case: 1 단계, 이미지 2개 중 2개
      • Prior to any repairs make sure that you are familiar with the device as well as the location of its buttons and ports.
      • Turn off device prior to continuing to further steps.
      댓글 쓰기
    2. SKYTEX SP1020 Battery Replacement: 2 단계, 이미지 3개 중 1개 SKYTEX SP1020 Battery Replacement: 2 단계, 이미지 3개 중 2개 SKYTEX SP1020 Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Set the tablet back panel facing down, with the SKYTEX logo facing you. You will find that this step will start from the right side of the device.
      • Insert the plastic opening tool between the bottom seam of the back panel and the micro SD port. The tool's edge should point toward the rear panel to prevent any scratching or damage.
      • Follow up with the plastic opening tool, releasing the clips as you go all the way around the device.
      댓글 쓰기
    3. SKYTEX SP1020 Battery Replacement: 3 단계, 이미지 1개 중 1개
      • The clips will be released in the order specified as the spudger tool is moved along the seam around the device.
      댓글 쓰기
    4. SKYTEX SP1020 Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to pry the speakers out of the rear case.
      • The rear case will now be free from the rest of the device.
      댓글 쓰기
    1. SKYTEX SP1020 Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
      • Locate the battery.
      댓글 쓰기
    2. SKYTEX SP1020 Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Use a soldering iron and desoldering braid to desolder the red and black motherboard battery connections.
      댓글 쓰기
    3. SKYTEX SP1020 Battery Replacement: 7 단계, 이미지 1개 중 1개
      • Gently lift the battery up and out of the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Anthony Vitali
회원 가입일: 03/23/15
293 평판
안내서 2개를 작성함
UMass Dartmouth, Team 1-6, Miles Spring 2015 UMass Dartmouth, Team 1-6, Miles Spring 2015 회원
UMASSD-MILES-S15S1G6
4 회원들
안내서 8개를 작성함
1가이드 댓글
Great Instructions! where did you get the battery for the Skytex ?
joe_capozzi - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 9
지난 30일: 34
전체 시간: 1,068
