주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SONOS ZP100 Network Card Replacement
필요한 것
    1. SONOS ZP100 Network Card Replacement, Lets begin!: 1 단계, 이미지 2개 중 1개 SONOS ZP100 Network Card Replacement, Lets begin!: 1 단계, 이미지 2개 중 2개
      • With the SONOS ZP100 (ZonePlayer) you can use external speakers to play your music that is streamed to the Sonos ZP100 via WiFi or cable.
      • The mute button and the volume buttons are located on the front.
      • On the back are the the four Ethernet ports, the connections for the speakers, subwoofer, audio-in and the power supply.
      • The integrated amplifier delivers an output of 2 x 50 watts.
      • With the Sonos S1 System App, the ZP100 can be controlled via a smartphone or a computer.
      댓글 쓰기
    2. SONOS ZP100 Network Card Replacement, Remove cover: 2 단계, 이미지 2개 중 1개 SONOS ZP100 Network Card Replacement, Remove cover: 2 단계, 이미지 2개 중 2개
      • The upper cover is fastened with two retaining lugs on the front and two on the sides.
      • There are fixed brackets on the back that cannot be pressed in.
      댓글 쓰기
    3. SONOS ZP100 Network Card Replacement: 3 단계, 이미지 3개 중 1개 SONOS ZP100 Network Card Replacement: 3 단계, 이미지 3개 중 2개 SONOS ZP100 Network Card Replacement: 3 단계, 이미지 3개 중 3개
      • Gently try to lift one side with a metal spudger. Make sure not to press in the retaining lug directly, as it can break off very easily.
      • When you've lifted one side, use an Opening Pick to keep the lid from snapping back into place.
      • Lift the lid up and out of its mounting towards the back.
      • Sharp-edged tools can cause scratches and leverage, which later remain visible on the device.
      댓글 쓰기
    4. SONOS ZP100 Network Card Replacement, Remove the screws from the upper case: 4 단계, 이미지 3개 중 1개 SONOS ZP100 Network Card Replacement, Remove the screws from the upper case: 4 단계, 이미지 3개 중 2개 SONOS ZP100 Network Card Replacement, Remove the screws from the upper case: 4 단계, 이미지 3개 중 3개
      • Using the precision tweezers to remove the sticker in the center of the top chassis.
      • Remove the three 35 mm Phillips screws and their washers that attach the top of the device to the bottom.
      • Even after removing the power plug, there may be dangerous charges on components in the device.
      댓글 쓰기
    5. SONOS ZP100 Network Card Replacement: 5 단계, 이미지 1개 중 1개
      • Now turn the device over so you can remove the screws on the bottom.
      댓글 쓰기
    6. SONOS ZP100 Network Card Replacement, Remove the rubber feet: 6 단계, 이미지 3개 중 1개 SONOS ZP100 Network Card Replacement, Remove the rubber feet: 6 단계, 이미지 3개 중 2개 SONOS ZP100 Network Card Replacement, Remove the rubber feet: 6 단계, 이미지 3개 중 3개
      • Use a spudger to remove the four stuck-on rubber feet. If necessary, use some heat (iOpener / hair dryer) to be able to loosen the feet better.
      댓글 쓰기
    7. SONOS ZP100 Network Card Replacement, Remove the base plate: 7 단계, 이미지 1개 중 1개
      • Remove the four 10 mm Phillips screws in the countersinks.
      댓글 쓰기
    8. SONOS ZP100 Network Card Replacement: 8 단계, 이미지 2개 중 1개 SONOS ZP100 Network Card Replacement: 8 단계, 이미지 2개 중 2개
      • Lift the bottom lid up and set it aside. You will need it again.
      • The two WiFi antennas are located on the underside. These can cause injury or break.
      댓글 쓰기
    9. SONOS ZP100 Network Card Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the four 10 mm Phillips screws on the bottom.
      댓글 쓰기
    10. SONOS ZP100 Network Card Replacement: 10 단계, 이미지 2개 중 1개 SONOS ZP100 Network Card Replacement: 10 단계, 이미지 2개 중 2개
      • For a better stand and to avoid damaging the antenna, put the lower cover back on and turn the device over.
      댓글 쓰기
    11. SONOS ZP100 Network Card Replacement, Remove the upper case: 11 단계, 이미지 2개 중 1개 SONOS ZP100 Network Card Replacement, Remove the upper case: 11 단계, 이미지 2개 중 2개
      • Lift the top lid straight up on both sides.
      댓글 쓰기
    12. SONOS ZP100 Network Card Replacement: 12 단계, 이미지 3개 중 1개 SONOS ZP100 Network Card Replacement: 12 단계, 이미지 3개 중 2개 SONOS ZP100 Network Card Replacement: 12 단계, 이미지 3개 중 3개
      • On the underside of the cover between the screws there are two heat conducting pads that transfer the heat generated from the amplifier-board to the case.
      • These Pads are very important, be careful not to lose them. They can either stick to the lid or in the device.
      댓글 쓰기
    13. SONOS ZP100 Network Card Replacement, Remove the WiFi card: 13 단계, 이미지 3개 중 1개 SONOS ZP100 Network Card Replacement, Remove the WiFi card: 13 단계, 이미지 3개 중 2개 SONOS ZP100 Network Card Replacement, Remove the WiFi card: 13 단계, 이미지 3개 중 3개
      • Press both tabs outwards with our fingernails.
      • The card should pop up by itself.
      • Pull out the card in the direction of the connector and place it in front of the device.
      • The WiFi card is still connected to the device with two cables. Be careful not to damage or tear them down.
      댓글 쓰기
    14. SONOS ZP100 Network Card Replacement: 14 단계, 이미지 2개 중 1개 SONOS ZP100 Network Card Replacement: 14 단계, 이미지 2개 중 2개
      • Pull the 10-pin flat connector straight off towards the front of the device.
      • Make sure to pull out the entire plug including all cables.
      댓글 쓰기
    15. SONOS ZP100 Network Card Replacement, Loosen the screws on the network card: 15 단계, 이미지 1개 중 1개
      • Remove the four 7 mm Phillips screws securing the network card to the case.
      댓글 쓰기
    16. SONOS ZP100 Network Card Replacement, Lift the network card: 16 단계, 이미지 3개 중 1개 SONOS ZP100 Network Card Replacement, Lift the network card: 16 단계, 이미지 3개 중 2개 SONOS ZP100 Network Card Replacement, Lift the network card: 16 단계, 이미지 3개 중 3개
      • Lift the network card up at an angle and pull it together with the ethernet ports towards the front a little bit out of its fixing on the back.
      • Carefully turn the network card to the side.
      • The network card is still connected to the bottom with two cables. Be careful not to damage them.
      댓글 쓰기
    17. SONOS ZP100 Network Card Replacement, Remove the ribbon cable: 17 단계, 이미지 3개 중 1개 SONOS ZP100 Network Card Replacement, Remove the ribbon cable: 17 단계, 이미지 3개 중 2개 SONOS ZP100 Network Card Replacement, Remove the ribbon cable: 17 단계, 이미지 3개 중 3개
      • Press the two tabs evenly away from the connector.
      • Gently pull the ribbon cable straight out of the connector toward the back.
      댓글 쓰기
    18. SONOS ZP100 Network Card Replacement, Turn the network card to the side: 18 단계, 이미지 1개 중 1개
      • Now you can turn the network card further outwards so it is easier to get to the next connector.
      댓글 쓰기
    19. SONOS ZP100 Network Card Replacement, Remove the power connection: 19 단계, 이미지 3개 중 1개 SONOS ZP100 Network Card Replacement, Remove the power connection: 19 단계, 이미지 3개 중 2개 SONOS ZP100 Network Card Replacement, Remove the power connection: 19 단계, 이미지 3개 중 3개
      • Remove the power cable from the network card. The plug is secured by a plastic tab. Push the nose away from the connector to pull it out.
      댓글 쓰기
    20. SONOS ZP100 Network Card Replacement, Remove network card: 20 단계, 이미지 1개 중 1개
      • The network card is now completely separated and cut from the power supply.
      댓글 쓰기
    21. SONOS ZP100 Network Card Replacement, Detach ribbon cable from Network Adapter board: 21 단계, 이미지 3개 중 1개 SONOS ZP100 Network Card Replacement, Detach ribbon cable from Network Adapter board: 21 단계, 이미지 3개 중 2개 SONOS ZP100 Network Card Replacement, Detach ribbon cable from Network Adapter board: 21 단계, 이미지 3개 중 3개
      • Press the two tabs evenly away from the socket.
      • Gently pull the ribbon cable to the Ethernet ports straight out of its socket on the network card.
      • Ribbon cables are very fragile handle with care.
      댓글 쓰기
    22. SONOS ZP100 Network Card Replacement, Network card: 22 단계, 이미지 2개 중 1개 SONOS ZP100 Network Card Replacement, Network card: 22 단계, 이미지 2개 중 2개
      • Front and back view of the network card.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
3다른 기여자 명과 함께
Adrian
회원 가입일: 12/20/13
345 평판
안내서 1개를 작성함
adrian büsselmann adrian büsselmann 회원
Business
1 회원
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 53
전체 시간: 2,375
