주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung A3 2016 Model - A310F Display / LCD Replacement
필요한 것
    1. Samsung A3 2016 Model - A310F Display / LCD Replacement, Display / LCD: 1 단계, 이미지 1개 중 1개
      • Remove the SIM tray from the phone.
      댓글 쓰기
    2. Samsung A3 2016 Model - A310F Display / LCD Replacement, Removing the battery cover: 2 단계, 이미지 1개 중 1개
      • Use a heat gun or iOpener to heat the back of the phone.
      • Insert a spudger or thin bladed tool between the batery cover and frame.
      • Slide all the way around to release the adhesive holding the cover.
      • The battery cover is also glass and can break if too much pressure is applied when removeing.
      댓글 쓰기
    3. Samsung A3 2016 Model - A310F Display / LCD Replacement: 3 단계, 이미지 2개 중 1개 Samsung A3 2016 Model - A310F Display / LCD Replacement: 3 단계, 이미지 2개 중 2개
      • Remove all 16 screws from the housing
      댓글 쓰기
    4. Samsung A3 2016 Model - A310F Display / LCD Replacement: 4 단계, 이미지 1개 중 1개
      • Hold the edge of the housing and push on the battery to release the display and mainboard from the housing.
      • You may need to go around the edge of the glass with a pick to remove any remaining adhesive
      댓글 쓰기
    5. Samsung A3 2016 Model - A310F Display / LCD Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the Philips screw securing the mainboard.
      • Remove the cable attached to the mainboard
      • Disconnect the display and camera connectors from the mainboard
      댓글 쓰기
    6. Samsung A3 2016 Model - A310F Display / LCD Replacement: 6 단계, 이미지 2개 중 1개 Samsung A3 2016 Model - A310F Display / LCD Replacement: 6 단계, 이미지 2개 중 2개
      • Disconnect the daughter board from the mainboard
      댓글 쓰기
    7. Samsung A3 2016 Model - A310F Display / LCD Replacement: 7 단계, 이미지 1개 중 1개
      • Using a heatgun, heat the front of the display.
      • Use a spudger or pick to work the display and LCD free from the plastic housing. NOTE: The LCD is also glued to the frame and will probably break as well.
      • When mounting the new display, the display cable slots through a gap in the plastic frame and attaches to the mainboard.
      댓글 쓰기
    8. Samsung A3 2016 Model - A310F Display / LCD Replacement: 8 단계, 이미지 3개 중 1개 Samsung A3 2016 Model - A310F Display / LCD Replacement: 8 단계, 이미지 3개 중 2개 Samsung A3 2016 Model - A310F Display / LCD Replacement: 8 단계, 이미지 3개 중 3개
      • Reattach the daughter board connector to the mainboard.
      • When re-inserting the mainboard, use a plastic spudger to push the battery pins in so the mainboard sits properly in the frame and the pins make a good contact with the battery.
      • Re-connect the display connector, camera and cable to the mainboard.
      • Screw the mainboard to the frame
      댓글 쓰기
    9. Samsung A3 2016 Model - A310F Display / LCD Replacement: 9 단계, 이미지 1개 중 1개
      • Turn the phone on and test the display before removing the adhesive on the back of the display.
      • If everything works, remove the adhesive and attach the display to the plastic frame.
      • Push the display into the metal housing so it fits snugly.
      댓글 쓰기
    10. Samsung A3 2016 Model - A310F Display / LCD Replacement: 10 단계, 이미지 2개 중 1개 Samsung A3 2016 Model - A310F Display / LCD Replacement: 10 단계, 이미지 2개 중 2개
      • Replace the 16 screws that were removed in step 3.
      • Replace the battery cover and you are done.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Harvey
회원 가입일: 02/15/16
6,435 평판
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 15
지난 30일: 56
전체 시간: 4,398
