주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung ATIV Smart PC 500T Front-Facing Camera Replacement
필요한 것
    1. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Backplate: 1 단계, 이미지 2개 중 1개 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Backplate: 1 단계, 이미지 2개 중 2개
      • Remove the stylus from the device.
      • Place the device screen-up on a hard surface, like a table.
      댓글 쓰기
    2. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: 2 단계, 이미지 3개 중 1개 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: 2 단계, 이미지 3개 중 2개 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: 2 단계, 이미지 3개 중 3개
      • Insert a plastic pry tool or opening pick between the glass and plastic case.
      • Work your way around the plastic edge, unclipping the backplate.
      • Once the clips are loosened, remove the backplate. Some force may be necessary.
      • Though you may need to use force, be careful of the pry tool slipping and hurting you!
      댓글 쓰기
    1. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Battery: 3 단계, 이미지 3개 중 1개 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Battery: 3 단계, 이미지 3개 중 2개 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Battery: 3 단계, 이미지 3개 중 3개
      • Disconnect the three ribbon cables from the motherboard to free the battery.
      • Use your finger to lift the flap securing each ZIF connector.
      • Slide the ribbon cable out and towards you. Now it should be completely detached.
      • Repeat with the other two cables.
      댓글 쓰기
    2. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: 4 단계, 이미지 3개 중 1개 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: 4 단계, 이미지 3개 중 2개 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: 4 단계, 이미지 3개 중 3개
      • Get a firm hold of the power cable as close to the clip as you can.
      • Pull the power cable up and out of the clip.
      댓글 쓰기
    3. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: 5 단계, 이미지 3개 중 1개 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: 5 단계, 이미지 3개 중 2개 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the six 3.5-mm screws using the Phillips #00 screwdriver.
      • Lift the battery out by hooking your finger under the tab on the top side of the battery and pulling it up and towards you. The battery should come out easily.
      댓글 쓰기
    1. Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Front-Facing Camera: 6 단계, 이미지 3개 중 1개 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Front-Facing Camera: 6 단계, 이미지 3개 중 2개 Samsung ATIV Smart PC 500T Front-Facing Camera Replacement, Front-Facing Camera: 6 단계, 이미지 3개 중 3개
      • Gently lift the front-facing camera with your forefinger.
      • Grip the camera with your thumb and forefinger and lift up to remove the camera from the socket at its base.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Crystal Dinh
회원 가입일: 09/23/15
1,062 평판
안내서 4개를 작성함
Baylor, Team 6-6, Williams Fall 2015 Baylor, Team 6-6, Williams Fall 2015 회원
BU-WILLIAMS-F15S6G6
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 49
전체 시간: 2,063
