주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Blackjack Antenna Replacement
필요한 것
    1. Samsung Blackjack Antenna Replacement, Battery Cover: 1 단계, 이미지 3개 중 1개 Samsung Blackjack Antenna Replacement, Battery Cover: 1 단계, 이미지 3개 중 2개 Samsung Blackjack Antenna Replacement, Battery Cover: 1 단계, 이미지 3개 중 3개
      • Hold the device with the screen facing away from you and the camera towards you.
      • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
      댓글 쓰기
    1. Samsung Blackjack Antenna Replacement, Battery: 2 단계, 이미지 2개 중 1개 Samsung Blackjack Antenna Replacement, Battery: 2 단계, 이미지 2개 중 2개
      • Place your fingers on both sides of the bottom of the battery and lift upwards.
      • Pull the battery away from the phone.
      댓글 쓰기
    1. Samsung Blackjack Antenna Replacement, SIM Card: 3 단계, 이미지 3개 중 1개 Samsung Blackjack Antenna Replacement, SIM Card: 3 단계, 이미지 3개 중 2개 Samsung Blackjack Antenna Replacement, SIM Card: 3 단계, 이미지 3개 중 3개
      • Place your thumb on the SIM card.
      • Slide the card out of the slot.
      댓글 쓰기
    1. Samsung Blackjack Antenna Replacement, Back Phone Casing: 4 단계, 이미지 2개 중 1개 Samsung Blackjack Antenna Replacement, Back Phone Casing: 4 단계, 이미지 2개 중 2개
      • Use the spudger to remove the rubber stoppers from the top of the cover.
      • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
      댓글 쓰기
    2. Samsung Blackjack Antenna Replacement: 5 단계, 이미지 3개 중 1개 Samsung Blackjack Antenna Replacement: 5 단계, 이미지 3개 중 2개 Samsung Blackjack Antenna Replacement: 5 단계, 이미지 3개 중 3개
      • Use the spudger to loosen and separate the front and back covers.
      • Pick up the back cover once loosened.
      • The front and back covers will be attached to each other by a gold wire.
      • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
      댓글 쓰기
    1. Samsung Blackjack Antenna Replacement, Antenna: 6 단계, 이미지 2개 중 1개 Samsung Blackjack Antenna Replacement, Antenna: 6 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Note: The antenna is located on the back case of the phone. Flip over the back case of the phone so that the interior is facing up.
      • Use spudger to help loosen the antenna.
      • Once the antenna is loose, use tweezers to remove antenna.
      댓글 쓰기
    2. Samsung Blackjack Antenna Replacement: 7 단계, 이미지 3개 중 1개 Samsung Blackjack Antenna Replacement: 7 단계, 이미지 3개 중 2개 Samsung Blackjack Antenna Replacement: 7 단계, 이미지 3개 중 3개
      • Use the Phillips 00 screwdriver to remove the screw from the casing around the speaker.
      • Use tweezers to lift the casing around the speaker.
      • Use spudger to dislodge the speaker.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Kristin Manna
회원 가입일: 10/22/12
29 평판
안내서 10개를 작성함
Clemson, Team 14-4, Benson Fall 2012 Clemson, Team 14-4, Benson Fall 2012 회원
CLEM-BENSON-F12S14G4
3 회원들
안내서 84개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 20
전체 시간: 826
