주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Blackjack Keypad Replacement
필요한 것
  1. Samsung Blackjack Keypad Replacement, Battery Cover: 1 단계, 이미지 3개 중 1개 Samsung Blackjack Keypad Replacement, Battery Cover: 1 단계, 이미지 3개 중 2개 Samsung Blackjack Keypad Replacement, Battery Cover: 1 단계, 이미지 3개 중 3개
    • Hold the device with the screen facing away from you and the camera towards you.
    • Place your thumb on the bottom half of the phone and slide the cover off while gently pushing down on the cover.
    댓글 쓰기
  2. Samsung Blackjack Keypad Replacement, Battery: 2 단계, 이미지 2개 중 1개 Samsung Blackjack Keypad Replacement, Battery: 2 단계, 이미지 2개 중 2개
    • Place your fingers on both sides of the bottom of the battery and lift upwards.
    • Pull the battery away from the phone.
    댓글 쓰기
  3. Samsung Blackjack Keypad Replacement, Back Phone Casing: 3 단계, 이미지 2개 중 1개 Samsung Blackjack Keypad Replacement, Back Phone Casing: 3 단계, 이미지 2개 중 2개
    • Use the spudger to remove the rubber stoppers from the top of the cover.
    • Use the Phillips 00 screw driver to remove the screws from each of the four corners and the two on sides (six total).
    댓글 쓰기
  4. Samsung Blackjack Keypad Replacement: 4 단계, 이미지 3개 중 1개 Samsung Blackjack Keypad Replacement: 4 단계, 이미지 3개 중 2개 Samsung Blackjack Keypad Replacement: 4 단계, 이미지 3개 중 3개
    • Use the spudger to loosen and separate the front and back covers.
    • Pick up the back cover once loosened.
    • The front and back covers will be attached to each other by a gold wire.
    • Remove the gold wire connecting the back cover to the motherboard to completely separate the covers.
    댓글 쓰기
  5. Samsung Blackjack Keypad Replacement, Motherboard: 5 단계, 이미지 2개 중 1개 Samsung Blackjack Keypad Replacement, Motherboard: 5 단계, 이미지 2개 중 2개
    • Use the spudger to unsnap the black rectangular connection from the motherboard.
    • Use the Phillips 00 screwdriver to remove all of the screws that hold the motherboard in place.
    댓글 쓰기
  6. Samsung Blackjack Keypad Replacement: 6 단계, 이미지 2개 중 1개 Samsung Blackjack Keypad Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the tweezers to unsnap the connection between the motherboard and the speaker. The speaker is attached to the front casing.
    댓글 쓰기
  7. Samsung Blackjack Keypad Replacement: 7 단계, 이미지 2개 중 1개 Samsung Blackjack Keypad Replacement: 7 단계, 이미지 2개 중 2개
    • Once all of the connections have been snapped off of the motherboard, the motherboard can be removed.
    • Lift up on the motherboard and it will come free of the front casing.
    댓글 쓰기
  8. Samsung Blackjack Keypad Replacement, Keypad: 8 단계, 이미지 1개 중 1개
    • Hold the front cover with the keypad facing you.
    • Push down on the keypad to remove it from the case. The keypad will come right out because there is nothing connecting it to the front casing.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Kristin Manna
회원 가입일: 10/22/12
29 평판
안내서 10개를 작성함
Clemson, Team 14-4, Benson Fall 2012 Clemson, Team 14-4, Benson Fall 2012 회원
CLEM-BENSON-F12S14G4
3 회원들
안내서 38개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 35
전체 시간: 807
