주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Chromebook 2 Battery Replacement
필요한 것
    1. Samsung Chromebook 2 Battery Replacement, Remove the screws to the Outer Case: 1 단계, 이미지 1개 중 1개
      • Using a PH0 bit, remove all 9 screws from the edges of the case.
      댓글 쓰기
    2. Samsung Chromebook 2 Battery Replacement, Opening the Case: 2 단계, 이미지 3개 중 1개 Samsung Chromebook 2 Battery Replacement, Opening the Case: 2 단계, 이미지 3개 중 2개 Samsung Chromebook 2 Battery Replacement, Opening the Case: 2 단계, 이미지 3개 중 3개
      • Open the MicroSD Card Reader door. It will assist when opening the case as there is a snap point directly beside this door.
      • Starting from the corner, slide your spudger down and in at a steep angle. You will hear a click as the snap loosens. Slid the spudger inside the case and turn 90° to the left or the right to release the snap.
      • Begin by slowly working your way around the case. If you come across a section that does not release as easy, leave it and go the opposite direction around the case. Eventually the pressure will release and the back case will pop off.
      • You can use the back casing as a screw tray for the battery, so keep it close.
      댓글 쓰기
    3. Samsung Chromebook 2 Battery Replacement, Disconnecting the Battery: 3 단계, 이미지 2개 중 1개 Samsung Chromebook 2 Battery Replacement, Disconnecting the Battery: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      Anti-Static Wrist Strap
      $7.95
      • Make sure you are wearing an anti static wrist strap, or make sure you are grounded. You are working close to the logic board, you do not want to cause static discharge damage!
      • Using your spudger, easily pry the battery cable from the connector. You may hear a click, this is normal. There are two snap in spots that keep the cable fastened tightly to the board.
      • I found it easier to slide the spudger under the side of the cable and lift gently. It only lifts a little of the cable at a time. I then moved the spudger to the other side of the cable and repeated. It gently disconnects from it's connector this way. (shown in picture 2)
      • Unscrew the four screws with your PH0 bit. Set them inside the case piece as it should prevent the screws from rolling around.
      • Once the battery is free, life the edge with the spudger and gently life the battery out of the chromebook.
      댓글 쓰기
    4. Samsung Chromebook 2 Battery Replacement, Replacing the Battery: 4 단계, 이미지 2개 중 1개 Samsung Chromebook 2 Battery Replacement, Replacing the Battery: 4 단계, 이미지 2개 중 2개
      • Put the new battery over the holding posts and gently put the cable onto the connecter. Gently push on one side at a time as there are two clasps that keep the cable connected. You will hear two clicks when the cable is seated correctly.
      • Take the flat part of your spudger and carefully verify the cable is fully seated.
      • Once the cable is seated, put the four screws back in. This will secure the battery.
      • Put the screws in loosely until all four are in place before tightening them down.
      댓글 쓰기
결론
To reassemble your device, place the back casing in its correct orientation. Apply gentle pressure around the edges until you hear no more clicks. Put all nine screws back in and tighten down.
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Zack McCauley
회원 가입일: 04/09/14
319 평판
안내서 1개를 작성함
2가이드 댓글
Thank you. The only thing that I might suggest is to point out that the battery connector is designed to be removed straight up, and inserted straight down, I was thinking that it went on by pushing it on to the ends of the pins from the bottom rather than it snapping onto the lengths of the pins straight down.
I appreciate your directions. They helped make this a very easy repair.
Paul Barwick - 답글 공유
Is there any danger of loosing any data during the battery replacement?
sallor225 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 44
전체 시간: 4,583
