주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Droid Charge SIM Card Port Replacement
필요한 것
  1. Samsung Droid Charge SIM Card Port Replacement, Rear Cover: 1 단계, 이미지 1개 중 1개
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
    댓글 쓰기
  2. Samsung Droid Charge SIM Card Port Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
    댓글 쓰기
  3. Samsung Droid Charge SIM Card Port Replacement, microSD: 3 단계, 이미지 1개 중 1개
    • Push the SD card further into its metal slot until you hear a click.
    • Release the card, and it should automatically eject itself.
    • Remove the SD card.
    댓글 쓰기
  4. Samsung Droid Charge SIM Card Port Replacement, SIM Card: 4 단계, 이미지 1개 중 1개
    • Slide the SIM card out of its casing by pushing on it and sliding it upward.
    댓글 쓰기
  5. Samsung Droid Charge SIM Card Port Replacement, SIM Card Port: 5 단계, 이미지 1개 중 1개
    • Carefully remove the back cover.
    • Remove the two 5mm screws with a small Phillips head screwdriver.
    댓글 쓰기
  6. Samsung Droid Charge SIM Card Port Replacement: 6 단계, 이미지 1개 중 1개
    • Removal of the back half of the casing.
    • Using a thin plastic flat head screw driver, or similar item. On the side of the phone insert the thin edge into the visible split between the 2 halves of the phone.
    • Use a prying motion to lift the casing up. This will separate the phone casing.
    • Repeat this motion all around the screen edge until the casing pops off.
    댓글 쓰기
  7. Samsung Droid Charge SIM Card Port Replacement: 7 단계, 이미지 1개 중 1개
    • Release the volume button flex cable on the right.
    • Release the pop connector on the motherboard located to the left of the SIM card port.
    댓글 쓰기
  8. Samsung Droid Charge SIM Card Port Replacement: 8 단계, 이미지 2개 중 1개 Samsung Droid Charge SIM Card Port Replacement: 8 단계, 이미지 2개 중 2개
    • Your SIM card port is now unattached.
    • Remove SIM card port from motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Lucas Carter
회원 가입일: 09/27/12
190 평판
안내서 1개를 작성함
Cal Poly, Team 15-44, Forte Fall 2012 Cal Poly, Team 15-44, Forte Fall 2012 회원
CPSU-FORTE-F12S15G44
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 23
지난 30일: 57
전체 시간: 2,824
