주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Droid Charge Screen Replacement
필요한 것
  1. Samsung Droid Charge Screen Replacement, Rear Cover: 1 단계, 이미지 1개 중 1개
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
    댓글 쓰기
  2. Samsung Droid Charge Screen Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
    댓글 쓰기
  3. Samsung Droid Charge Screen Replacement, microSD: 3 단계, 이미지 1개 중 1개
    • Push the SD card further into its metal slot until you hear a click.
    • Release the card, and it should automatically eject itself.
    • Remove the SD card.
    댓글 쓰기
  4. Samsung Droid Charge Screen Replacement, SIM Card: 4 단계, 이미지 1개 중 1개
    • Slide the SIM card out of its casing by pushing on it and sliding it upward.
    댓글 쓰기
  5. Samsung Droid Charge Screen Replacement, Screen: 5 단계, 이미지 1개 중 1개
    • Locate the 7 small black screws located around the edge of the phone under the battery cover.
    • With a small Philips head screwdriver, remove each of the screws and place them in a secure location.
    댓글 쓰기
  6. Samsung Droid Charge Screen Replacement: 6 단계, 이미지 1개 중 1개
    • Locate your pry tool.
    • Insert the pry tool into the plastic edge that runs along the sides of the phone. Doing so will allow you to remove part of the back casing.
    • Use a prying motion to lift the casing up.
    • Repeat this motion all around the screen edge until the casing pops off.
    댓글 쓰기
  7. Samsung Droid Charge Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Release the one pop connector for the motherboard located on the right.
    • Release the volume button flex cable on the right.
    • Release the power button flex cable on the right.
    • Now the motherboard can be removed. Simply lift out the motherboard and set aside.
    댓글 쓰기
  8. Samsung Droid Charge Screen Replacement: 8 단계, 이미지 3개 중 1개 Samsung Droid Charge Screen Replacement: 8 단계, 이미지 3개 중 2개 Samsung Droid Charge Screen Replacement: 8 단계, 이미지 3개 중 3개
    • Using a hairdryer or heat gun, warm the phone. Doing so will warm the adhesive holding the screen in place, allowing us to continue disassembling the device.
    • Use the pry tool to pry the screen off the casing. You may need to use force to overcome the adhesive.
    • Work carefully to prevent damage to the phone.
    댓글 쓰기
  9. Samsung Droid Charge Screen Replacement: 9 단계, 이미지 1개 중 1개
    • You can now swap out the old screen for your new one.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Luke Gordon
회원 가입일: 09/26/12
199 평판
안내서 5개를 작성함
Cal Poly, Team 15-44, Forte Fall 2012 Cal Poly, Team 15-44, Forte Fall 2012 회원
CPSU-FORTE-F12S15G44
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 24
전체 시간: 3,474
