주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Epic 4G Camera Lens Replacement
필요한 것
  1. Samsung Epic 4G Camera Lens Replacement, Phone Case: 1 단계, 이미지 1개 중 1개
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
    댓글 쓰기
  2. Samsung Epic 4G Camera Lens Replacement: 2 단계, 이미지 1개 중 1개
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
    댓글 쓰기
  3. Samsung Epic 4G Camera Lens Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove the battery from the device by pulling the battery edge upwards.
    댓글 쓰기
  4. Samsung Epic 4G Camera Lens Replacement, Removing the Memory Card:: 4 단계, 이미지 1개 중 1개
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
    댓글 쓰기
  5. Samsung Epic 4G Camera Lens Replacement, Removing the Back Housing: 5 단계, 이미지 2개 중 1개 Samsung Epic 4G Camera Lens Replacement, Removing the Back Housing: 5 단계, 이미지 2개 중 2개
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
    댓글 쓰기
  6. Samsung Epic 4G Camera Lens Replacement, Removing the Power Button: 6 단계, 이미지 2개 중 1개 Samsung Epic 4G Camera Lens Replacement, Removing the Power Button: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
    댓글 쓰기
  7. Samsung Epic 4G Camera Lens Replacement, Micro USB Port: 7 단계, 이미지 1개 중 1개
    • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
    • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
    • Do not rip the white cables out of the device.
    댓글 쓰기
  8. Samsung Epic 4G Camera Lens Replacement, Removing the Antenna Assembly: 8 단계, 이미지 2개 중 1개 Samsung Epic 4G Camera Lens Replacement, Removing the Antenna Assembly: 8 단계, 이미지 2개 중 2개
    • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
    • Snap the antenna assembly out of the device gently using your fingers.
    댓글 쓰기
  9. Samsung Epic 4G Camera Lens Replacement, Removing the Flex Cable: 9 단계, 이미지 2개 중 1개 Samsung Epic 4G Camera Lens Replacement, Removing the Flex Cable: 9 단계, 이미지 2개 중 2개
    • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
    • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
    댓글 쓰기
  10. Samsung Epic 4G Camera Lens Replacement: 10 단계, 이미지 1개 중 1개
    • Lift and remove the motherboard from the device.
    • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
    댓글 쓰기
  11. Samsung Epic 4G Camera Lens Replacement, Camera Lens: 11 단계, 이미지 1개 중 1개
    • Remove and replace the camera lens with a new one from a manufacturer.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Andrew Cunningham
회원 가입일: 10/03/12
273 평판
안내서 6개를 작성함
Cal Poly, Team 24-25, Regan Fall 2012 Cal Poly, Team 24-25, Regan Fall 2012 회원
CPSU-REGAN-F12S24G25
4 회원들
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 29
전체 시간: 1,439
