주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Epic 4G Power Button Replacement
필요한 것
  1. Samsung Epic 4G Power Button Replacement, Phone Case: 1 단계, 이미지 1개 중 1개
    • Slide your fingernail along the edge of the device and pull at the plastic backing.
    • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
    댓글 쓰기
  2. Samsung Epic 4G Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Pull at the plastic backing gently to remove it after hearing the snap sound.
    댓글 쓰기
  3. Samsung Epic 4G Power Button Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Remove the battery from the device by pulling the battery edge upwards.
    댓글 쓰기
  4. Samsung Epic 4G Power Button Replacement, Removing the Memory Card:: 4 단계, 이미지 1개 중 1개
    • Locate the memory card on the upper right-hand corner of the device.
    • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
    댓글 쓰기
  5. Samsung Epic 4G Power Button Replacement, Removing the Back Housing: 5 단계, 이미지 2개 중 1개 Samsung Epic 4G Power Button Replacement, Removing the Back Housing: 5 단계, 이미지 2개 중 2개
    • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
    • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
    • While separating the two components, most of the buttons (including the power button) will fall out.
    댓글 쓰기
  6. Samsung Epic 4G Power Button Replacement, Removing the Power Button: 6 단계, 이미지 2개 중 1개 Samsung Epic 4G Power Button Replacement, Removing the Power Button: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the power button using tweezers if it did not fall out in the previous step.
    • At this point, you can replace the power button with a new one from a manufacturer.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Andrew Cunningham
회원 가입일: 10/03/12
273 평판
안내서 6개를 작성함
Cal Poly, Team 24-25, Regan Fall 2012 Cal Poly, Team 24-25, Regan Fall 2012 회원
CPSU-REGAN-F12S24G25
4 회원들
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 34
전체 시간: 2,760
