주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Epix Keyboard Replacement
필요한 것
    1. Samsung Epix Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Just below the phone's camera, press the button and hold it
      • While the button is held down, slide the back panel off to remove it completely.
      댓글 쓰기
    2. Samsung Epix Keyboard Replacement: 2 단계, 이미지 1개 중 1개
      • Grasp the bottom corners of the battery with two fingers and gently lift.
      • Gently lift the battery and remove it from the phone.
      댓글 쓰기
    1. Samsung Epix Keyboard Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
      • Using a plastic prying tool, remove the screw cover in the top left corner of the phone by lifting it up.
      • Be gentle
      댓글 쓰기
    2. Samsung Epix Keyboard Replacement: 4 단계, 이미지 1개 중 1개
      • Use the Phillips #00 screwdriver to remove the six screws on the back of the phone.
      • Three of the screws are evenly spaced on the left and right side on the back of the phone.
      • The upper right screw is 4.5mm while the rest are 6.5mm.
      댓글 쓰기
    3. Samsung Epix Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Samsung Epix Keyboard Replacement: 5 단계, 이미지 2개 중 2개
      • Insert the prying tool into the seam on the side of the phone and turn it slightly. Do this for each of the eight clips to unhook them
      • There are three clips on each side and two at the bottom of the phone.
      댓글 쓰기
    4. Samsung Epix Keyboard Replacement: 6 단계, 이미지 1개 중 1개
      • Once all eight of the clips have been unhooked, lift the back panel gently off of the phone.
      • Be careful and do not attempt to remove the front panel. It is still connected to the phone's chassis by a ribbon cable which is located in the bottom right side of the motherboard.
      댓글 쓰기
    5. Samsung Epix Keyboard Replacement: 7 단계, 이미지 1개 중 1개
      • Using the plastic prying tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
      • Carefully disconnect the ribbon cable.
      댓글 쓰기
    6. Samsung Epix Keyboard Replacement: 8 단계, 이미지 1개 중 1개
      • Gently lift and remove the front faceplate
      • Exercise caution
      댓글 쓰기
    7. Samsung Epix Keyboard Replacement: 9 단계, 이미지 1개 중 1개
      • Grasp the rubber keyboard in the corner with your fingers and lift to remove it.
      • Lift it and gently take it out the frame to remove it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Chris
회원 가입일: 04/20/11
32 평판
안내서 1개를 작성함
Cal Poly, Team 15-15, Regan Spring 2011 Cal Poly, Team 15-15, Regan Spring 2011 회원
CPSU-REGAN-S11S15G15
5 회원들
안내서 35개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 37
전체 시간: 2,062
