주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Epix LCD Display Replacement
필요한 것
    1. Samsung Epix LCD Display Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Just below the phone's camera, press the button and hold it
      • While the button is held down, slide the back panel off to remove it completely.
      댓글 쓰기
    2. Samsung Epix LCD Display Replacement: 2 단계, 이미지 1개 중 1개
      • Grasp the bottom corners of the battery with two fingers and gently lift.
      • Gently lift the battery and remove it from the phone.
      댓글 쓰기
    1. Samsung Epix LCD Display Replacement, LCD Display: 3 단계, 이미지 1개 중 1개
      • Remove the rubber screw cover in the top left corner by prying upwards with an opening tool.
      댓글 쓰기
    2. Samsung Epix LCD Display Replacement: 4 단계, 이미지 1개 중 1개
      • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone.
      • The upper right screw is 4.5 mm and the others are 6.5 mm.
      댓글 쓰기
    3. Samsung Epix LCD Display Replacement: 5 단계, 이미지 2개 중 1개 Samsung Epix LCD Display Replacement: 5 단계, 이미지 2개 중 2개
      • Slide the opening tool along the seam on the side of the phone and turn it slightly to unhook the eight clips.
      • There are three clips on each side and two at the bottom of the phone.
      댓글 쓰기
    4. Samsung Epix LCD Display Replacement: 6 단계, 이미지 1개 중 1개
      • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
      • Be careful not to remove the front panel. It will still be connected to the phone chassis by a ribbon cable on the motherboard.
      댓글 쓰기
    5. Samsung Epix LCD Display Replacement: 7 단계, 이미지 1개 중 1개
      • Using an opening tool, undo the ZIF connector halfway up the right side.
      • Carefully remove ribbon cable.
      댓글 쓰기
    6. Samsung Epix LCD Display Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the front faceplate by lifting it off of the phone chassis.
      댓글 쓰기
    7. Samsung Epix LCD Display Replacement: 9 단계, 이미지 1개 중 1개
      • Using the opening tool, unlatch the LCD ribbon cable.
      댓글 쓰기
    8. Samsung Epix LCD Display Replacement: 10 단계, 이미지 1개 중 1개
      • Using an opening tool or spudger, pry under the lower left and right corners of the LCD screen.
      • The LCD is held in place to the chassis with adhesive strips.
      • Do not pry excessively hard. You may damage the circuitry on the back of the LCD.
      댓글 쓰기
    9. Samsung Epix LCD Display Replacement: 11 단계, 이미지 1개 중 1개
      • Lift the LCD display out from phone chassis.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Mark Wyse
회원 가입일: 04/19/11
62 평판
안내서 2개를 작성함
Cal Poly, Team 15-15, Regan Spring 2011 Cal Poly, Team 15-15, Regan Spring 2011 회원
CPSU-REGAN-S11S15G15
5 회원들
안내서 35개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 29
전체 시간: 2,263
