주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Eternity Digitizer and Screen Replacement
필요한 것
    • Remove the back battery cover.
    댓글 쓰기
  1. Samsung Eternity Digitizer and Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Using a nylon spudger, remove the phone's battery.
    댓글 쓰기
  2. Samsung Eternity Digitizer and Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
    댓글 쓰기
  3. Samsung Eternity Digitizer and Screen Replacement: 4 단계, 이미지 2개 중 1개 Samsung Eternity Digitizer and Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
    댓글 쓰기
  4. Samsung Eternity Digitizer and Screen Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
    댓글 쓰기
  5. Samsung Eternity Digitizer and Screen Replacement: 6 단계, 이미지 3개 중 1개 Samsung Eternity Digitizer and Screen Replacement: 6 단계, 이미지 3개 중 2개 Samsung Eternity Digitizer and Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
    댓글 쓰기
  6. Samsung Eternity Digitizer and Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
    댓글 쓰기
  7. Samsung Eternity Digitizer and Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Peel the button sensor on the side of the motherboard off of the case.
    댓글 쓰기
  8. Samsung Eternity Digitizer and Screen Replacement: 9 단계, 이미지 3개 중 1개 Samsung Eternity Digitizer and Screen Replacement: 9 단계, 이미지 3개 중 2개 Samsung Eternity Digitizer and Screen Replacement: 9 단계, 이미지 3개 중 3개
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
    댓글 쓰기
  9. Samsung Eternity Digitizer and Screen Replacement: 10 단계, 이미지 1개 중 1개
    • You have successfully removed the motherboard from the phone.
    댓글 쓰기
  10. Samsung Eternity Digitizer and Screen Replacement, Digitizer and Screen: 11 단계, 이미지 1개 중 1개
    • Flip the phone over so you are looking at the front screen of the phone.
    댓글 쓰기
  11. Samsung Eternity Digitizer and Screen Replacement: 12 단계, 이미지 3개 중 1개 Samsung Eternity Digitizer and Screen Replacement: 12 단계, 이미지 3개 중 2개 Samsung Eternity Digitizer and Screen Replacement: 12 단계, 이미지 3개 중 3개
    • Use a small tool to pry the digitizer and screen (together) from the frame of the phone.
    • This may take some time and careful work because it is glued down to the frame.
    • Be careful when you pull the lower part of this piece away from the phone frame because there is a ribbon attached to the digitizer that you don't want to break. There is also a ribbon on the side of the screen to be aware of.
    댓글 쓰기
  12. Samsung Eternity Digitizer and Screen Replacement: 13 단계, 이미지 3개 중 1개 Samsung Eternity Digitizer and Screen Replacement: 13 단계, 이미지 3개 중 2개 Samsung Eternity Digitizer and Screen Replacement: 13 단계, 이미지 3개 중 3개
    • Next, carefully pull the digitizer away from the screen.
    • At this point you can replace either the screen or the digitizer.
    • Cleaning the screen with a glass cleaning cloth before reassembling will remove any smudges or fingerprints from disassembling the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Heather Behrend
회원 가입일: 04/20/11
142 평판
안내서 1개를 작성함
Cal Poly, Team 15-11, Regan Spring 2011 Cal Poly, Team 15-11, Regan Spring 2011 회원
CPSU-REGAN-S11S15G11
5 회원들
안내서 28개를 작성함
3가이드 댓글
You did not mention how to glue the digitizer to LCD. That is a very important step.
cashyapan - 답글 공유
Do these steps also work for the Samsung Eternity 2?
Brian Coukis The 90's Kid! - 답글 공유
Está mierda no sale
Luz esther Martinez Pérez - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 35
전체 시간: 7,341
