주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy A11 Display Assembly Replacement
필요한 것
  1. Samsung Galaxy A11 Display Assembly Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Samsung Galaxy A11 Display Assembly Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Samsung Galaxy A11 Display Assembly Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Place the SIM eject tool in the hole of the sim tray.
    • Push until part of the SIM tray is pushed out.
    • Pull out the rest of the SIM tray.
    댓글 쓰기
  2. Samsung Galaxy A11 Display Assembly Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy A11 Display Assembly Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy A11 Display Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Gently pry open the area of the back cover near the SIM tray using an iFixit opening pick.
    • Gently move the pick along the gap and pry open the clips holding it together.
    • If possible, use multiple picks to prevent the back cover from closing.
    댓글 쓰기
  3. Samsung Galaxy A11 Display Assembly Replacement: 3 단계, 이미지 3개 중 1개 Samsung Galaxy A11 Display Assembly Replacement: 3 단계, 이미지 3개 중 2개 Samsung Galaxy A11 Display Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • Using a hair dryer on low heat, heat the fingerprint sensor in increments of 30 seconds to loosen the surrounding adhesive.
    • Gently push the fingerprint sensor until it detaches from the back cover.
    • If needed, remove the button by prying it from the bottom of the device.
    댓글 쓰기
  4. Samsung Galaxy A11 Display Assembly Replacement, Battery: 4 단계, 이미지 3개 중 1개 Samsung Galaxy A11 Display Assembly Replacement, Battery: 4 단계, 이미지 3개 중 2개 Samsung Galaxy A11 Display Assembly Replacement, Battery: 4 단계, 이미지 3개 중 3개
    • Remove the three 3 mm screws from the shield using a Phillips #000 screwdriver.
    • Remove the shield from the phone.
    댓글 쓰기
  5. Samsung Galaxy A11 Display Assembly Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy A11 Display Assembly Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy A11 Display Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Using tweezers, a spudger, or your fingers, disconnect the battery press connector from the phone.
    댓글 쓰기
  6. Samsung Galaxy A11 Display Assembly Replacement: 6 단계, 이미지 3개 중 1개 Samsung Galaxy A11 Display Assembly Replacement: 6 단계, 이미지 3개 중 2개 Samsung Galaxy A11 Display Assembly Replacement: 6 단계, 이미지 3개 중 3개
    • If needed, use a hairdryer on low heat to soften the adhesive under the battery. If The Battery Is Expanded, DO NOT USE A HAIRDRYER or heat; be very careful when removing to not puncture the battery.
    • Use an iFixit pry tool to dig under the battery edge.
    • If needed, use multiple pry tools to hold the battery in place.
    • Continue to cut the adhesive under the battery until you are able to pry the battery away from the phone.
    • Remove the battery from the phone.
    댓글 쓰기
  7. Samsung Galaxy A11 Display Assembly Replacement, Earpiece Speaker: 7 단계, 이미지 3개 중 1개 Samsung Galaxy A11 Display Assembly Replacement, Earpiece Speaker: 7 단계, 이미지 3개 중 2개 Samsung Galaxy A11 Display Assembly Replacement, Earpiece Speaker: 7 단계, 이미지 3개 중 3개
    • Gently use tweezers to peel up the copper strip on the top right of the phone.
    댓글 쓰기
  8. Samsung Galaxy A11 Display Assembly Replacement: 8 단계, 이미지 2개 중 1개 Samsung Galaxy A11 Display Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the three black 3 mm screws from the speaker cover using a Phillips #000 screwdriver.
    • Remove the cover from the phone.
    댓글 쓰기
  9. Samsung Galaxy A11 Display Assembly Replacement: 9 단계, 이미지 3개 중 1개 Samsung Galaxy A11 Display Assembly Replacement: 9 단계, 이미지 3개 중 2개 Samsung Galaxy A11 Display Assembly Replacement: 9 단계, 이미지 3개 중 3개
    • Using tweezers, carefully remove the earpiece speaker at the top of the phone.
    • When using metal tools, it is important to be gentle in order to not damage the device.
    • If needed, you can use a hair dryer to apply heat to the speaker and loosen the adhesive.
    • If needed, you may orient the tweezers to your liking, gripping the earpiece horizontally or vertically, while removing it.
    댓글 쓰기
  10. Samsung Galaxy A11 Display Assembly Replacement, Fingerprint Sensor: 10 단계, 이미지 3개 중 1개 Samsung Galaxy A11 Display Assembly Replacement, Fingerprint Sensor: 10 단계, 이미지 3개 중 2개 Samsung Galaxy A11 Display Assembly Replacement, Fingerprint Sensor: 10 단계, 이미지 3개 중 3개
    • Using a spudger, detach the ribbon cable connected to the fingerprint sensor.
    • Remove the fingerprint sensor from the device.
    댓글 쓰기
  11. Samsung Galaxy A11 Display Assembly Replacement, Motherboard: 11 단계, 이미지 1개 중 1개
    • Remove the two 3 mm silver screws from the top left of the device using a Phillips #000 screwdriver.
    댓글 쓰기
  12. Samsung Galaxy A11 Display Assembly Replacement: 12 단계, 이미지 3개 중 1개 Samsung Galaxy A11 Display Assembly Replacement: 12 단계, 이미지 3개 중 2개 Samsung Galaxy A11 Display Assembly Replacement: 12 단계, 이미지 3개 중 3개
    • Using a spudger, disconnect the two ribbon cables attached to the battery slot from the motherboard.
    • Disconnect the two longer ribbon cables near the bottom right corner of the motherboard.
    • Lift these cables up slightly to reveal a gap.
    댓글 쓰기
  13. Samsung Galaxy A11 Display Assembly Replacement: 13 단계, 이미지 3개 중 1개 Samsung Galaxy A11 Display Assembly Replacement: 13 단계, 이미지 3개 중 2개 Samsung Galaxy A11 Display Assembly Replacement: 13 단계, 이미지 3개 중 3개
    • Using a spudger, gently pry the motherboard up using the corner revealed in the previous step.
    • If needed, use a metal spudger as a sturdier alternative.
    • If using a metal spudger, it is important to be gentle in order to not damage any components of the device.
    • Remove the motherboard from the device.
    댓글 쓰기
  14. Samsung Galaxy A11 Display Assembly Replacement, Daughterboard: 14 단계, 이미지 3개 중 1개 Samsung Galaxy A11 Display Assembly Replacement, Daughterboard: 14 단계, 이미지 3개 중 2개 Samsung Galaxy A11 Display Assembly Replacement, Daughterboard: 14 단계, 이미지 3개 중 3개
    • Remove the eight silver and black 3 mm screws from the speaker cover using a Phillips #000 screwdriver.
    • Remove the speaker cover from the device.
    댓글 쓰기
  15. Samsung Galaxy A11 Display Assembly Replacement: 15 단계, 이미지 3개 중 1개 Samsung Galaxy A11 Display Assembly Replacement: 15 단계, 이미지 3개 중 2개 Samsung Galaxy A11 Display Assembly Replacement: 15 단계, 이미지 3개 중 3개
    • Using a spudger, disconnect the antenna heads from the daughterboard.
    • Disconnect the ribbon cable from the daughterboard.
    댓글 쓰기
  16. Samsung Galaxy A11 Display Assembly Replacement: 16 단계, 이미지 3개 중 1개 Samsung Galaxy A11 Display Assembly Replacement: 16 단계, 이미지 3개 중 2개 Samsung Galaxy A11 Display Assembly Replacement: 16 단계, 이미지 3개 중 3개
    • Using tweezers, gently pry the daughterboard from the device.
    댓글 쓰기
  17. Samsung Galaxy A11 Display Assembly Replacement, Vibration Motor: 17 단계, 이미지 2개 중 1개 Samsung Galaxy A11 Display Assembly Replacement, Vibration Motor: 17 단계, 이미지 2개 중 2개
    • Using tweezers, remove the vibrator motor from the device.
    • If needed, you can apply heat to loosen the adhesive from the motor.
    댓글 쓰기
  18. Samsung Galaxy A11 Display Assembly Replacement, Display Assembly: 18 단계, 이미지 1개 중 1개
    • The display assembly is separated from all other components and can be replaced.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Chloe Bulloch
회원 가입일: 09/04/24
789 평판
안내서 3개를 작성함
Utah Tech University, Team 1-6, Crenshaw Fall 2024 Utah Tech University, Team 1-6, Crenshaw Fall 2024 회원
UTAHTECH-CRENSHAW-F24S1G6
2 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 42
지난 30일: 201
전체 시간: 2,808
