주요 콘텐츠로 건너뛰기
Samsung Galaxy Book Pro 15" Battery Replacement
필요한 것
  1. Samsung Galaxy Book Pro 15" Battery Replacement, Remove the rubber feet: 1 단계, 이미지 1/3 Samsung Galaxy Book Pro 15" Battery Replacement, Remove the rubber feet: 1 단계, 이미지 2/3 Samsung Galaxy Book Pro 15" Battery Replacement, Remove the rubber feet: 1 단계, 이미지 3/3
    • Before you begin, power down your laptop and unplug it.
    • There are two kinds of rubber feet along the top and bottom of the rear case. Keep track of their position as you remove them.
    • Insert an opening pick between the rubber foot and the rear case.
    • Pry up with the opening pick to release the clips securing the foot.
    • Remove the foot.
    • Repeat this procedure for the three remaining feet.
    • During reassembly, press the feet into their correct slot to reinsert them. Mismatched feet won't fit correctly.
  2. Samsung Galaxy Book Pro 15" Battery Replacement, Unfasten the rear case: 2 단계, 이미지 1/2 Samsung Galaxy Book Pro 15" Battery Replacement, Unfasten the rear case: 2 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the rear case.
    • If you're reassembling with the Samsung Self-Repair kit, be sure to replace the screws with new ones labeled #3313.
  3. Samsung Galaxy Book Pro 15" Battery Replacement, Insert an opening pick: 3 단계, 이미지 1/3 Samsung Galaxy Book Pro 15" Battery Replacement, Insert an opening pick: 3 단계, 이미지 2/3 Samsung Galaxy Book Pro 15" Battery Replacement, Insert an opening pick: 3 단계, 이미지 3/3
    • Apply a suction cup to the rear case, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear case and the frame.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy Book Pro 15" Battery Replacement, Release the clips: 4 단계, 이미지 1/3 Samsung Galaxy Book Pro 15" Battery Replacement, Release the clips: 4 단계, 이미지 2/3 Samsung Galaxy Book Pro 15" Battery Replacement, Release the clips: 4 단계, 이미지 3/3
    • Slide the pick along the bottom edge of the rear case to release its plastic clips.
    • Repeat this process for the left and right edges, but stop before reaching the top edge.
  5. Samsung Galaxy Book Pro 15" Battery Replacement, Remove the rear case: 5 단계, 이미지 1/3 Samsung Galaxy Book Pro 15" Battery Replacement, Remove the rear case: 5 단계, 이미지 2/3 Samsung Galaxy Book Pro 15" Battery Replacement, Remove the rear case: 5 단계, 이미지 3/3
    • The top edge of the rear case is lightly adhered to the frame.
    • Pull the top of the rear case away from the frame to separate the adhesive and release the remaining clips.
    • If you're having trouble separating the adhesive, use an iOpener, hair dryer, or heat gun to soften it.
    • Remove the rear case.
    • During reassembly, perform the following:
    • If you're using a using a genuine Samsung replacement rear case, be sure to peel off any adhesive liners from the rear case before securing the top edge's clips.
    • If you're reusing your rear case, you can use some pre-cut adhesive to re-adhere the top edge if your existing adhesive is no longer sticky.
    • This is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down completely before you continue working.
  6. Samsung Galaxy Book Pro 15" Battery Replacement, Disconnect the battery: 6 단계, 이미지 1/2 Samsung Galaxy Book Pro 15" Battery Replacement, Disconnect the battery: 6 단계, 이미지 2/2
    • Insert a spudger between the frame and the bottom of the battery cable connector.
    • Pry up and disconnect the battery cable connector.
  7. Samsung Galaxy Book Pro 15" Battery Replacement, Unfasten the battery: 7 단계, 이미지 1/2 Samsung Galaxy Book Pro 15" Battery Replacement, Unfasten the battery: 7 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the four 4.5 mm-long screws securing the battery.
    • Take care not to puncture the battery with your screwdriver—a punctured battery may leak dangerous chemicals or cause a fire.
  8. Samsung Galaxy Book Pro 15" Battery Replacement, Remove the battery: 8 단계, 이미지 1/3 Samsung Galaxy Book Pro 15" Battery Replacement, Remove the battery: 8 단계, 이미지 2/3 Samsung Galaxy Book Pro 15" Battery Replacement, Remove the battery: 8 단계, 이미지 3/3
    • Lift the battery straight out of the frame and remove it.
결론
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing." Skip steps that use heating and prying, and pay close attention to the 📌 bullets as you work through the steps.
For optimal performance, calibrate your newly installed battery after completing this guide.
다른 한 분이 해당 안내서를 완성하였습니다.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
124,744 평판
안내서 582개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,303개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 46
30일 전: 195
전체 시간: 2,728
