주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Camera 2 Flash Replacement
필요한 것
    1. Samsung Galaxy Camera 2 Flash Replacement, Screen: 1 단계, 이미지 3개 중 1개 Samsung Galaxy Camera 2 Flash Replacement, Screen: 1 단계, 이미지 3개 중 2개 Samsung Galaxy Camera 2 Flash Replacement, Screen: 1 단계, 이미지 3개 중 3개
      • While holding the camera, take note of each screw holding the screen to the main chassis of the camera.
      • Hold the camera upright and lens facing towards you. There area total of six 4mm PH00 screws to undo - two on the left, one screw on the right, and three along the bottom. Two of them are hidden behind the battery compartment door.
      댓글 쓰기
    2. Samsung Galaxy Camera 2 Flash Replacement: 2 단계, 이미지 1개 중 1개
      • Use the screwdriver to remove screws listed in step 2. There are a total of six 4mm screws.
      댓글 쓰기
    3. Samsung Galaxy Camera 2 Flash Replacement: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Camera 2 Flash Replacement: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Camera 2 Flash Replacement: 3 단계, 이미지 3개 중 3개
      • With the screws removed, use the plastic opening tool to gently pry the screen away from the main camera chassis. The ideal spot to start is at the corner with the headphone jack, as indicated in the picture.
      • Once this side is free, gently work your way along the edge, all the way around the camera body.
      댓글 쓰기
    4. Samsung Galaxy Camera 2 Flash Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Camera 2 Flash Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Camera 2 Flash Replacement: 4 단계, 이미지 3개 중 3개
      • With the screen freed, gently lay the camera on its face, so that the battery compartment faces up. Use both hands to lift the screen up and away.
      • The screen is still attached to the motherboard by a ribbon cable. Be Gentle as it's very fragile.
      댓글 쓰기
    5. Samsung Galaxy Camera 2 Flash Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Camera 2 Flash Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Camera 2 Flash Replacement: 5 단계, 이미지 3개 중 3개
      • With the screen separated from the main chassis, use the plastic opening tool to gently pry the edge of the ribbon cable connector from the motherboard.
      댓글 쓰기
    6. Samsung Galaxy Camera 2 Flash Replacement, Screen Separated: 6 단계, 이미지 1개 중 1개
      • Now the screen is removed.
      • Set the body aside in a safe place.
      댓글 쓰기
    1. Samsung Galaxy Camera 2 Flash Replacement, Lens Assembly: 7 단계, 이미지 3개 중 1개 Samsung Galaxy Camera 2 Flash Replacement, Lens Assembly: 7 단계, 이미지 3개 중 2개 Samsung Galaxy Camera 2 Flash Replacement, Lens Assembly: 7 단계, 이미지 3개 중 3개
      • After removing the screen and battery to access to the inside of the camera, take note of the two main assemblies inside-- the lens apparatus and the main motherboard. The lens assembly is on the left hand side.
      • There are three small silver screws (4mm PH00) to remove.
      댓글 쓰기
    2. Samsung Galaxy Camera 2 Flash Replacement: 8 단계, 이미지 3개 중 1개 Samsung Galaxy Camera 2 Flash Replacement: 8 단계, 이미지 3개 중 2개 Samsung Galaxy Camera 2 Flash Replacement: 8 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • With the three screws removed, take note of the two ribbon cables connecting the lens assembly to the main motherboard.
      • Use the tweezers to remove the two green strips of tape protecting the connectors.
      • Use the plastic opening tool to release the black clips locking in the ribbon cables, then use the tweezers to gently pull the ribbon cables away from the main motherboard.
      댓글 쓰기
    3. Samsung Galaxy Camera 2 Flash Replacement: 9 단계, 이미지 3개 중 1개 Samsung Galaxy Camera 2 Flash Replacement: 9 단계, 이미지 3개 중 2개 Samsung Galaxy Camera 2 Flash Replacement: 9 단계, 이미지 3개 중 3개
      • Now that the screws and ribbon cables have been removed, gently pull the lens assembly up from the the camera and remove it.
      댓글 쓰기
    1. Samsung Galaxy Camera 2 Flash Replacement, Motherboard: 10 단계, 이미지 3개 중 1개 Samsung Galaxy Camera 2 Flash Replacement, Motherboard: 10 단계, 이미지 3개 중 2개 Samsung Galaxy Camera 2 Flash Replacement, Motherboard: 10 단계, 이미지 3개 중 3개
      • Now that you've removed the battery, screen, and lens assembly, you are ready to continue inremoving the motherboard.
      • There are small ribbon cables connected to the motherboard. Use your plastic opening tool and gently pry the sides of the connectors away from the motherboard. Tuck them away to prevent damaging them when removing the motherboard.
      댓글 쓰기
    2. Samsung Galaxy Camera 2 Flash Replacement: 11 단계, 이미지 3개 중 1개 Samsung Galaxy Camera 2 Flash Replacement: 11 단계, 이미지 3개 중 2개 Samsung Galaxy Camera 2 Flash Replacement: 11 단계, 이미지 3개 중 3개
      • After removing the ribbon cables, take note of the screws holding the motherboard into the main chassis of the camera.
      • There are two types of screws to remove. The four (2mm, PH00) circled in red have a fat head, and go in the gold contact.
      • The three (4mm, PH00) screws marked in green have a skinny head.
      • Use the IFIXIT screwdriver and PH0 bit to remove all the screws holding the motherboard.
      댓글 쓰기
    3. Samsung Galaxy Camera 2 Flash Replacement: 12 단계, 이미지 3개 중 1개 Samsung Galaxy Camera 2 Flash Replacement: 12 단계, 이미지 3개 중 2개 Samsung Galaxy Camera 2 Flash Replacement: 12 단계, 이미지 3개 중 3개
      • With all the screws removed, use the plastic opening tool to gently pry the headphone jack away from its casing. That jack holds the motherboard in place.
      • Next, gently slide the plastic opening tool underneath the motherboard. Move your fingers underneath and use your hands to completely remove it.
      댓글 쓰기
    4. Samsung Galaxy Camera 2 Flash Replacement: 13 단계, 이미지 3개 중 1개 Samsung Galaxy Camera 2 Flash Replacement: 13 단계, 이미지 3개 중 2개 Samsung Galaxy Camera 2 Flash Replacement: 13 단계, 이미지 3개 중 3개
      • Now, remove the motherboard completely from the chassis.
      댓글 쓰기
    1. Samsung Galaxy Camera 2 Flash Replacement, Flash: 14 단계, 이미지 3개 중 1개 Samsung Galaxy Camera 2 Flash Replacement, Flash: 14 단계, 이미지 3개 중 2개 Samsung Galaxy Camera 2 Flash Replacement, Flash: 14 단계, 이미지 3개 중 3개
      • Underneath the motherboard, there is a thin metal plate. This plate should lift up easily, as there are no screws keeping it in place.
      댓글 쓰기
    2. Samsung Galaxy Camera 2 Flash Replacement: 15 단계, 이미지 2개 중 1개 Samsung Galaxy Camera 2 Flash Replacement: 15 단계, 이미지 2개 중 2개
      • Now, all that's left is the frame and black interior frame. To get to the flash assembly, the black frame must be entirely removed.
      • Due to the abundance of small parts, it may be easy to lose some.
      • As a general rule, the black screws belong to the black frame, and silver screws go through the black frame directly into the casing of the camera.
      댓글 쓰기
    3. Samsung Galaxy Camera 2 Flash Replacement: 16 단계, 이미지 3개 중 1개 Samsung Galaxy Camera 2 Flash Replacement: 16 단계, 이미지 3개 중 2개 Samsung Galaxy Camera 2 Flash Replacement: 16 단계, 이미지 3개 중 3개
      • Before you can take out the black frame, make sure to remove the silver accents on the casing. Use the plastic opening tool to gently pry them off.
      • Although not necessary, it is advisable to remove the silver cover from the flash. Take out the two screws holding it together and gently pop off the top with the plastic opening tool. We chose to put it back on for the rest of the guide to add stability to the piece.
      댓글 쓰기
    4. Samsung Galaxy Camera 2 Flash Replacement: 17 단계, 이미지 3개 중 1개 Samsung Galaxy Camera 2 Flash Replacement: 17 단계, 이미지 3개 중 2개 Samsung Galaxy Camera 2 Flash Replacement: 17 단계, 이미지 3개 중 3개
      • Next, gently use the plastic opening tool to pry the black frame out of the casing. The frame should lift out easily. If you feel some resistance, you may have missed a screw.
      댓글 쓰기
    5. Samsung Galaxy Camera 2 Flash Replacement: 18 단계, 이미지 2개 중 1개 Samsung Galaxy Camera 2 Flash Replacement: 18 단계, 이미지 2개 중 2개
      • Now, looking at the black frame, the top left corner is the flash mechanism.
      • Taking out the two (3mm PH00) screws from the plastic flash cap frees the light bulb so that it can be changed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sofia Isern
회원 가입일: 02/10/16
520 평판
안내서 2개를 작성함
USF Tampa, Team 14-5, Lacy Spring 2016 USF Tampa, Team 14-5, Lacy Spring 2016 회원
USFT-LACY-S16S14G5
3 회원들
안내서 13개를 작성함
2가이드 댓글
Hi! Where can i buy this samsung galaxy camera 2 flash unit?
Juan Andres Gonzalez Velez - 답글 공유
hi where can i get samsung galaxy camera 2 flash light
Melwin Mendis - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 43
전체 시간: 3,882
