주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Express 3 Battery Replacement
  1. Samsung Galaxy Express 3 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Express 3 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
    댓글 쓰기
  2. Samsung Galaxy Express 3 Battery Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Express 3 Battery Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Express 3 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Kellie Speck
회원 가입일: 04/24/18
136 평판
안내서 1개를 작성함
2가이드 댓글
Petra:
Hi I’m from Central South America and I recently got this phone for my birthday. I dropped it while at the swimming pool for my party THE SAME DAY I GOT IT and I was really sad. #sad I found your steps a-maz-ing. It helped me not only unclog the water that had corroded the battery inside, but I was able to successfully dry my phone out and replace it without too much hassle. The pictures were especially helpful because English is my fourth language. Thank you Kellie!
Mack Johnson - 답글 공유
I am so thrilled!
-Kels
Stephen Pettinger - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 31
전체 시간: 1,711
