주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Express 3 Screen Replacement
필요한 것
  1. Samsung Galaxy Express 3 Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Express 3 Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Locate the indent area highlighted in red and use either your fingernail or a Prying Tool (such as a guitar pick) to separate the back from the body of the phone.
    댓글 쓰기
  2. Samsung Galaxy Express 3 Screen Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Express 3 Screen Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Express 3 Screen Replacement: 2 단계, 이미지 3개 중 3개
    • Once the cover is removed, locate the battery that reads "SAMSUNG."
    • Use either your fingernail or a Plastic Prying Tool (such as a guitar pick) to lift up the bottom indent of the battery.
    • Do not use a metal tool, as it can cause injury.
    댓글 쓰기
  3. Samsung Galaxy Express 3 Screen Replacement, Screen: 3 단계, 이미지 2개 중 1개 Samsung Galaxy Express 3 Screen Replacement, Screen: 3 단계, 이미지 2개 중 2개
    • Use a Plastic Prying Tool (such as a spudger) to pop out piece shown.
    댓글 쓰기
  4. Samsung Galaxy Express 3 Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Detach the screen connector.
    댓글 쓰기
  5. Samsung Galaxy Express 3 Screen Replacement: 5 단계, 이미지 2개 중 1개 Samsung Galaxy Express 3 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Use a blow dryer or heating pad to heat up the screen.
    • Do not skip this step, as it may result in a broken screen and/or LCD.
    • This step loosens the glue holding the screen in place.
    댓글 쓰기
  6. Samsung Galaxy Express 3 Screen Replacement: 6 단계, 이미지 3개 중 1개 Samsung Galaxy Express 3 Screen Replacement: 6 단계, 이미지 3개 중 2개 Samsung Galaxy Express 3 Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Use a Thin Plastic Tool (such as a guitar pick) or Plastic Prying Tool (such as a spudger) to lift out the glass digitizer and LCD screen around the edges.
    • Do this slowly and carefully, as both parts can crack very easily.
    • Ensure your tool is plastic, as a metal tool can damage the screen easily.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mack Johnson
회원 가입일: 04/05/18
996 평판
안내서 6개를 작성함
2가이드 댓글
My friend set on his phone the screen is broken. The phone will come on but the screen will not light up.
Rudolph Mc Alister - 답글 공유
Same! For TWO phones now… have you had any luck on any suggestions or figuring anything out???
Faith Dockery - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 59
전체 시간: 4,197
