주요 콘텐츠로 건너뛰기
Samsung Galaxy J3 (2016) Battery Replacement
필요한 것
  1. Samsung Galaxy J3 (2016) Battery Replacement, Rear Cover: 1 단계, 이미지 1/2 Samsung Galaxy J3 (2016) Battery Replacement, Rear Cover: 1 단계, 이미지 2/2
    • Insert a fingernail or the flat end of a spudger into the divot to the left of the rear-facing camera.
    • Gently pry the rear cover away from the phone until all the plastic clips holding the cover are released.
  2. Samsung Galaxy J3 (2016) Battery Replacement: 2 단계, 이미지 1/1
    • Remove the rear cover.
    • To reinstall the rear cover, align it to the back of the phone, and squeeze the perimeter of the phone to snap all the clips into place.
  3. Samsung Galaxy J3 (2016) Battery Replacement, Battery: 3 단계, 이미지 1/3 Samsung Galaxy J3 (2016) Battery Replacement, Battery: 3 단계, 이미지 2/3 Samsung Galaxy J3 (2016) Battery Replacement, Battery: 3 단계, 이미지 3/3
    • Insert a fingernail or the flat end of a spudger into the divot below the battery pack.
    • Pry the battery pack out of its recess.
    • If you use the spudger, do not push too hard or you will puncture the battery pack.
    • Remove the battery pack.
결론
Repair didn’t go as planned? Check out our Samsung Galaxy J3 (2016) Answers community for troubleshooting help.
다른 7명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
257,468 평판
안내서 529개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 한 개
Hmm I can't seem to get the back cover off my phone. This phone is a POS, always has been. It's slow, hard to use, and for almost 300.00 bucks it lasted about 2 years. What a racket these phone companies have going.
Mare Tomaski - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 19
30일 전: 107
전체 시간: 12,632
