주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Mega Rear Facing Camera Replacement
필요한 것
  1. Samsung Galaxy Mega Rear Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 1개 Samsung Galaxy Mega Rear Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 2개 Samsung Galaxy Mega Rear Facing Camera Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
    댓글 쓰기
  2. Samsung Galaxy Mega Rear Facing Camera Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Mega Rear Facing Camera Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Mega Rear Facing Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
    댓글 쓰기
  3. Samsung Galaxy Mega Rear Facing Camera Replacement, Midframe: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Mega Rear Facing Camera Replacement, Midframe: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Mega Rear Facing Camera Replacement, Midframe: 3 단계, 이미지 3개 중 3개
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
    댓글 쓰기
  4. Samsung Galaxy Mega Rear Facing Camera Replacement: 4 단계, 이미지 2개 중 1개 Samsung Galaxy Mega Rear Facing Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
    댓글 쓰기
  5. Samsung Galaxy Mega Rear Facing Camera Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Remove the 2.55 mm Phillips #000 screw from the motherboard panel.
    댓글 쓰기
  6. Samsung Galaxy Mega Rear Facing Camera Replacement: 6 단계, 이미지 3개 중 1개 Samsung Galaxy Mega Rear Facing Camera Replacement: 6 단계, 이미지 3개 중 2개 Samsung Galaxy Mega Rear Facing Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the connector clips on motherboard.
    댓글 쓰기
  7. Samsung Galaxy Mega Rear Facing Camera Replacement: 7 단계, 이미지 2개 중 1개 Samsung Galaxy Mega Rear Facing Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the final motherboard connectors.
    댓글 쓰기
  8. Samsung Galaxy Mega Rear Facing Camera Replacement: 8 단계, 이미지 3개 중 1개 Samsung Galaxy Mega Rear Facing Camera Replacement: 8 단계, 이미지 3개 중 2개 Samsung Galaxy Mega Rear Facing Camera Replacement: 8 단계, 이미지 3개 중 3개
    • Lift motherboard gently with finger.
    • There is a total of six connectors on the motherboard that need to be removed. All of them are shown in the pictures in this guide, make sure all of them are disconnected before removing.
    댓글 쓰기
  9. Samsung Galaxy Mega Rear Facing Camera Replacement, Rear Facing Camera: 9 단계, 이미지 2개 중 1개 Samsung Galaxy Mega Rear Facing Camera Replacement, Rear Facing Camera: 9 단계, 이미지 2개 중 2개
    • On the back of the motherboard, remove the connector of the rear facing camera from the motherboard.
    • Camera is now detached from device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Max Rathman
회원 가입일: 02/04/16
915 평판
안내서 4개를 작성함
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S17G2
4 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 46
전체 시간: 1,120
