주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Mega USB Board Replacement
필요한 것
  1. Samsung Galaxy Mega USB Board Replacement, Battery: 1 단계, 이미지 3개 중 1개 Samsung Galaxy Mega USB Board Replacement, Battery: 1 단계, 이미지 3개 중 2개 Samsung Galaxy Mega USB Board Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before starting, ensure device is completely turned off.
    • On the back of phone, locate the slot on the top left corner.
    • Insert plastic opening tool or fingernail and pull up on the back plate.
    • With the corner released, slide your finger around the device between the back plate and the phone to release connectors.
    댓글 쓰기
  2. Samsung Galaxy Mega USB Board Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Mega USB Board Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Mega USB Board Replacement: 2 단계, 이미지 3개 중 3개
    • Insert fingernail into the slot on bottom of battery and gently pull up.
    • Remove the battery.
    댓글 쓰기
  3. Samsung Galaxy Mega USB Board Replacement, Midframe: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Mega USB Board Replacement, Midframe: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Mega USB Board Replacement, Midframe: 3 단계, 이미지 3개 중 3개
    • Remove the 14 3.45 mm Phillips #000 screws from the assembly.
    • Gently, insert plastic opening tool into seam above the volume buttons of your phone.
    • You may substitute metal spudger for plastic opening tool to first start the opening of the seam. This may cause exterior cosmetic damage.
    댓글 쓰기
  4. Samsung Galaxy Mega USB Board Replacement: 4 단계, 이미지 2개 중 1개 Samsung Galaxy Mega USB Board Replacement: 4 단계, 이미지 2개 중 2개
    • Slowly slide plastic opening tool around the device to release all the connectors internal to the device.
    • The device should easily come apart after the plastic opening tool is slid around the entire device.
    • During reassembly, ensure volume and power buttons align properly.
    댓글 쓰기
  5. Samsung Galaxy Mega USB Board Replacement, USB Board: 5 단계, 이미지 1개 중 1개
    • This circuit board is the charging port assembly.
    댓글 쓰기
  6. Samsung Galaxy Mega USB Board Replacement: 6 단계, 이미지 3개 중 1개 Samsung Galaxy Mega USB Board Replacement: 6 단계, 이미지 3개 중 2개 Samsung Galaxy Mega USB Board Replacement: 6 단계, 이미지 3개 중 3개
    • Lift up on the clamp with your finger to disconnect the connector.
    • Lift up on the clamp with your finger to disconnect the connection to the mother board.
    • Grasp cable head and lift up to disconnect the cable head.
    댓글 쓰기
  7. Samsung Galaxy Mega USB Board Replacement: 7 단계, 이미지 2개 중 1개 Samsung Galaxy Mega USB Board Replacement: 7 단계, 이미지 2개 중 2개
    • Use your fingers to gently remove charging port.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Aaron Fulton
회원 가입일: 02/04/16
1,246 평판
안내서 3개를 작성함
USF Tampa, Team 17-2, Blackwell Winter 2016 USF Tampa, Team 17-2, Blackwell Winter 2016 회원
USFT-BLACKWELL-W16S17G2
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 33
전체 시간: 9,129
