주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note Midframe Replacement
필요한 것
  1. Samsung Galaxy Note Midframe Replacement, Rear Case: 1 단계, 이미지 2개 중 1개 Samsung Galaxy Note Midframe Replacement, Rear Case: 1 단계, 이미지 2개 중 2개
    • Pry with a plastic opening tool, or your fingernail, in the divot to the right of the rear-facing camera, near the volume rocker.
    댓글 쓰기
  2. Samsung Galaxy Note Midframe Replacement: 2 단계, 이미지 2개 중 1개 Samsung Galaxy Note Midframe Replacement: 2 단계, 이미지 2개 중 2개
    • Lift and remove the rear case from the phone.
    댓글 쓰기
  3. Samsung Galaxy Note Midframe Replacement, Battery: 3 단계, 이미지 2개 중 1개 Samsung Galaxy Note Midframe Replacement, Battery: 3 단계, 이미지 2개 중 2개
    • Insert your finger in the notch of the battery compartment.
    • Press the battery toward the rear facing camera while pulling outward.
    댓글 쓰기
  4. Samsung Galaxy Note Midframe Replacement, MicroSD Card: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Note Midframe Replacement, MicroSD Card: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Note Midframe Replacement, MicroSD Card: 4 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the microSD card into the slot until it clicks in place.
    댓글 쓰기
  5. Samsung Galaxy Note Midframe Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the microSD card from its slot in the midframe.
    댓글 쓰기
  6. Samsung Galaxy Note Midframe Replacement, SIM Card: 6 단계, 이미지 2개 중 1개 Samsung Galaxy Note Midframe Replacement, SIM Card: 6 단계, 이미지 2개 중 2개
    • Use a plastic opening tool, or your fingernail, to push the SIM card out of its compartment.
    댓글 쓰기
  7. Samsung Galaxy Note Midframe Replacement: 7 단계, 이미지 2개 중 1개 Samsung Galaxy Note Midframe Replacement: 7 단계, 이미지 2개 중 2개
    • Slide the SIM card out the rest of the way with your thumb and remove it from the device.
    댓글 쓰기
  8. Samsung Galaxy Note Midframe Replacement, Midframe: 8 단계, 이미지 1개 중 1개
    • Remove the nine 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
    댓글 쓰기
  9. Samsung Galaxy Note Midframe Replacement: 9 단계, 이미지 2개 중 1개 Samsung Galaxy Note Midframe Replacement: 9 단계, 이미지 2개 중 2개
    • Insert your plastic opening tool to the left of the power button between the midframe and the front panel assembly and pry.
    댓글 쓰기
  10. Samsung Galaxy Note Midframe Replacement: 10 단계, 이미지 3개 중 1개 Samsung Galaxy Note Midframe Replacement: 10 단계, 이미지 3개 중 2개 Samsung Galaxy Note Midframe Replacement: 10 단계, 이미지 3개 중 3개
    • Slide the plastic opening tool down the seam.
    댓글 쓰기
  11. Samsung Galaxy Note Midframe Replacement: 11 단계, 이미지 3개 중 1개 Samsung Galaxy Note Midframe Replacement: 11 단계, 이미지 3개 중 2개 Samsung Galaxy Note Midframe Replacement: 11 단계, 이미지 3개 중 3개
    • Insert your plastic opening tool to the left of the headphone jack between the midframe and the display assembly.
    • Slide the opening tool along the top edge of the phone.
    • Continue to run the plastic opening tool around the perimeter of the phone until the midframe is separated.
    댓글 쓰기
  12. Samsung Galaxy Note Midframe Replacement: 12 단계, 이미지 2개 중 1개 Samsung Galaxy Note Midframe Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the midframe from the display assembly.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 16명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
477,674 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 28,226개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 49
전체 시간: 11,398
