주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note8 Back Cover Replacement
필요한 것
  1. Samsung Galaxy Note8 Back Cover Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Switch off your phone.
    • Prepare an iOpener for softening the adhesive on the back of the Note8.
    • Apply the iOpener on the back of the Note8 along the side with the power button.
  2. Samsung Galaxy Note8 Back Cover Replacement: 2 단계, 이미지 3개 중 1개 Samsung Galaxy Note8 Back Cover Replacement: 2 단계, 이미지 3개 중 2개 Samsung Galaxy Note8 Back Cover Replacement: 2 단계, 이미지 3개 중 3개
    • Use a suction handle to lift the back cover and create an opening pick to get in the gap.
    • Since the back cover is also slightly curved at the edges you want to insert the opening pick at a lower angle from underneath.
    • Start at the middle of the side and cut the adhesive while pulling up with the suction handle.
    • Be careful not to lever the opening pick too much to avoid breaking the back cover. Rather pull with the suction handle and use the pick for cutting the adhesive.
    • Move the pick towards the bottom corner and leave it there to keep the adhesive from resealing to the case.
    • Use another pick and move it to the top corner.
    • If it's getting harder to move the pick you might need to reheat the iOpener and apply it to the back cover again.
  3. Samsung Galaxy Note8 Back Cover Replacement: 3 단계, 이미지 3개 중 1개 Samsung Galaxy Note8 Back Cover Replacement: 3 단계, 이미지 3개 중 2개 Samsung Galaxy Note8 Back Cover Replacement: 3 단계, 이미지 3개 중 3개
    • Again take another opening pick and carefully move it around the corner and along the top edge.
    • Reheat with an iOpener if necessary.
    • Leave the pick at the top right corner to keep the adhesive from resealing.
  4. Samsung Galaxy Note8 Back Cover Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy Note8 Back Cover Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy Note8 Back Cover Replacement: 4 단계, 이미지 3개 중 3개
    • Rotate the device and start to separate the adhesive at the bottom with another opening pick.
    • Leave the pick at the bottom right corner to keep the adhesive from resealing.
  5. Samsung Galaxy Note8 Back Cover Replacement: 5 단계, 이미지 3개 중 1개 Samsung Galaxy Note8 Back Cover Replacement: 5 단계, 이미지 3개 중 2개 Samsung Galaxy Note8 Back Cover Replacement: 5 단계, 이미지 3개 중 3개
    • When the adhesive has been separated on all three sides properly you will be able to slowly lift the back cover.
    • Don't force it open. Use an iOpener to again soften the adhesive if the back cover won't come off or starts to bend.
    • Pay attention to the fingerprint sensor connector when flipping the back cover open. You might need to disconnect it as described in the next step.
  6. Samsung Galaxy Note8 Back Cover Replacement: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to disconnect the fingerprint sensor.
    • The connector might already have come off when flipping the back cover open.
  7. Samsung Galaxy Note8 Back Cover Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the back cover.
    • To prepare for the reassembly remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
결론
If possible, turn on your phone and test the new part before installing new adhesive and resealing the phone.
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
After installing the rear cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
다른 43명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tobias Isakeit
회원 가입일: 03/31/14
133,366 평판
안내서 189개를 작성함
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,145개를 작성함
3가이드 댓글
My adhivsive was a pain in the but! Never fixed a phone that hard glued :O
Vidar G - 답글 공유
the separate adhesive was unneeded the replacement back cover came with adhesive
Anthony Asp - 답글 공유
So close!!!!’ I sliced the fingerprint sensor cable off, that area of the back glass was so smashed. Hopefully I can get a replacement to me by Saturday
Douglas Pocknett Jr - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 33
지난 30일: 171
전체 시간: 33,099
