주요 콘텐츠로 건너뛰기
Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement
필요한 것
  1. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Rear Case: 1 단계, 이미지 2개 중 1개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Rear Case: 1 단계, 이미지 2개 중 2개
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 2 단계, 이미지 2개 중 1개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 3 단계, 이미지 2개 중 1개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 3 단계, 이미지 2개 중 2개
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 4 단계, 이미지 2개 중 1개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 5 단계, 이미지 2개 중 1개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 5 단계, 이미지 2개 중 2개
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
  6. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Battery: 6 단계, 이미지 2개 중 1개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Battery: 6 단계, 이미지 2개 중 2개
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 7 단계, 이미지 2개 중 1개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the battery.
  8. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, SIM Card: 8 단계, 이미지 3개 중 1개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, SIM Card: 8 단계, 이미지 3개 중 2개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, SIM Card: 8 단계, 이미지 3개 중 3개
    • Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the SIM card into the slot until it clicks in place.
  9. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 9 단계, 이미지 3개 중 1개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 9 단계, 이미지 3개 중 2개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 9 단계, 이미지 3개 중 3개
    • Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it.
    • Grasp and remove the SIM card away from the phone.
  10. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, microSD Card: 10 단계, 이미지 3개 중 1개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, microSD Card: 10 단계, 이미지 3개 중 2개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, microSD Card: 10 단계, 이미지 3개 중 3개
    • Using your fingernail, push the microSD card slightly deeper into its slot, until you hear a click.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  11. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 11 단계, 이미지 2개 중 1개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 11 단계, 이미지 2개 중 2개
    • Use your thumb to slide the microSD card out of the slot.
    • Remove the microSD card from the phone.
  12. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Plastic Midframe: 12 단계, 이미지 1개 중 1개
    • Remove the ten 4.0 mm Phillips screws securing the midframe to the front panel assembly.
  13. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 13 단계, 이미지 2개 중 1개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 13 단계, 이미지 2개 중 2개
    • Grasp the left side of the plastic midframe with your thumb and forefinger and lift it away from the phone.
    • The midframe lightly snaps in place, and can be removed with very little force.
  14. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: 14 단계, 이미지 2개 중 1개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement, Headphone Jack/Speaker Assembly: 14 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry the rear-facing camera connector up from its socket on the motherboard.
    • Make sure you are prying on the connector and not the socket, or you may damage the motherboard.
  15. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 15 단계, 이미지 2개 중 1개 Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 15 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool outboard of the speaker portion of the headphone jack/speaker assembly.
    • Gently pry the headphone jack/speaker assembly up from the front assembly.
  16. Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement: 16 단계, 이미지 1개 중 1개
    • Lift the headphone jack/speaker assembly out of the Galaxy S III.
결론
다른 98명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Walter Galan
701,243 평판
안내서 1,203개를 작성함
댓글 11개
Thanks for the guide. It's the most detailed that I have seen so far. I'm looking for a headphone jack assembly replacement part that is compatible with a verizon s3 (i535), but they are difficult to find. Some of the sellers on ebay are advertising that their replacement for the i9300 is compatible with the i535, but I am not sure. Can you please tell me where you purchased your headphone jack assembly replacement?
Thanks!
Wendy
Wendy - 답글
I completed the tutorial but still have sound through the left and only on the right when I spin the jack AND apply pressure towards the phone. The part was brand new and all connections look good at a glance. I must have missed something though. Any ideas?
Nick - 답글
i had the same problem (no sound through the right ear)
i followed the repair guide, teared it apart and then, when i had the jack out of it i used a flashlight and a soldering iron
my guide:
use a very thin soldering iron, make it really hot, put very much solder on it
then stick it in the jack you have to be VERY FAST!!! otherwise the plastic will melt
now you have solder on the contacts and they touch the headphone plug again :)
worked fine for me, but only do this when you know how to solder!
it's a little risky but it's worth it
cheers
Markus
markuslindner1 - 답글
Ich habe mir das Teil besorgt und wollte es einbauen, habe aber 2 Schreuben nicht aufgedreht bekommen. Jetzt ist der Kopf ausgenudelt. Was kann ich machen?
atzeborg - 답글
Thanks for the guide. We just replaced speaker assembly in my son's S3 with a $9 part off ebay, and it's working perfectly. Everything went like the pictures except there was slight difference between original and replacement. The hole next to the speaker in the replacement was a full circle, as in the last photo above, but the original was just a half-circle. We had to trim and file the replacement to match. Once we did that, it all snapped back together like new.
Greg - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 26
지난 30일: 35
전체 시간: 91,349
