소개
Follow this guide to remove the back cover for replacement, or to access the Galaxy S10+’s internals. This guide works with either the standard glass back, or the ceramic back.
필요한 것
Unplug and power off your phone before you begin.
Heat an iOpener and apply it to the back cover's right edge for two minutes.
As you wait, take a look at the image of the removed back cover and take note of where the adhesive is located.
Apply a suction cup to the back of the phone, as close to the center of the right edge as possible (where the adhesive is narrowest).
Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
Insert the point of an opening pick into the gap.
If you are having trouble creating a gap, your best bet is to apply more heat to the edge and try the previous step again.
You can try applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
Rest the heated right edge of the phone on something that is about 0.5 inches (13 mm) thick. This angles the phone for the opening tool.
Brace the left edge of the phone with your fingers so that the phone won't slide. Pull on the suction cup with firm pressure.
Press the edge of an opening tool into the seam between the back cover and the frame.
Slide the opening tool back and forth along the seam a few times.
Slide the opening pick along the edge of the phone, slicing through the adhesive.
Leave a pick in the seam to prevent the adhesive from re-sealing.
After you've completed the repair, follow this guide to test your repair.
다른 27명이 해당 안내서를 완성하였습니다.
댓글 7개
Good guide, pretty easy to follow along
si le cambio la tapa trasera a mi s10 plus deja de funcionar bajo el agua?
That’s correct. The phone will not be water resistant.
Eso es correcto. El teléfono no será resistente al agua.
then How can I keep it water-resistant?
Jeet z -
