주요 콘텐츠로 건너뛰기
Samsung Galaxy S10+ Rear-Facing Camera Module Replacement
필요한 것
  1. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, SIM/MicroSD Card: 1 단계, 이미지 3개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, SIM/MicroSD Card: 1 단계, 이미지 3개 중 2개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, SIM/MicroSD Card: 1 단계, 이미지 3개 중 3개
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located at the top edge of the phone next to the plastic antenna band.
    • If you inserted the tool into the other hole, don't worry—the microphone and the ingress gasket are mounted out of harm's way.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  2. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Heat the back cover: 2 단계, 이미지 3개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Heat the back cover: 2 단계, 이미지 3개 중 2개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Heat the back cover: 2 단계, 이미지 3개 중 3개
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take a look at the image of the removed back cover and take note of where the adhesive is located.
  3. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Create an opening gap: 3 단계, 이미지 3개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Create an opening gap: 3 단계, 이미지 3개 중 2개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Create an opening gap: 3 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible (where the adhesive is narrowest).
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts.
    • If you are having trouble creating a gap, your best bet is to apply more heat to the edge and try the previous step again.
    • You can try applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
    • Do not apply excessive force with the pick, or you will risk cracking the back cover glass.
  4. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 4 단계, 이미지 3개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 4 단계, 이미지 3개 중 2개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 4 단계, 이미지 3개 중 3개
    • Rest the heated right edge of the phone on something that is about 0.5 inches (13 mm) thick. This angles the phone for the opening tool.
    • Brace the left edge of the phone with your fingers so that the phone won't slide. Pull on the suction cup with firm pressure.
    • Press the edge of an opening tool into the seam between the back cover and the frame.
    • Slide the opening tool back and forth along the seam a few times.
  5. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Slice through the adhesive: 5 단계, 이미지 3개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Slice through the adhesive: 5 단계, 이미지 3개 중 2개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Slice through the adhesive: 5 단계, 이미지 3개 중 3개
    • Slide the opening pick along the edge of the phone, slicing through the adhesive.
    • Do not attempt to slice the adhesive holding the corners down before applying heat. If you do, you may crack the back cover.
    • Leave a pick in the seam to prevent the adhesive from re-sealing.
  6. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 6 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the bottom edge of the phone for two minutes.
  7. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 7 단계, 이미지 2개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 7 단계, 이미지 2개 중 2개
    • Insert an opening pick into the right edge near the bottom right corner.
    • Carefully slide the pick around the corner. Continue cutting along the bottom edge and around the bottom left corner.
    • If the cutting feels difficult, re-apply heat to the edge before continuing.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
  8. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 8 단계, 이미지 3개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 8 단계, 이미지 3개 중 2개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 8 단계, 이미지 3개 중 3개
    • Continue heating and slicing around the remaining edges of the phone.
    • When cutting around corners, be sure that the corner is thoroughly heated.
  9. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 9 단계, 이미지 3개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 9 단계, 이미지 3개 중 2개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 9 단계, 이미지 3개 중 3개
    • Once you have sliced around the phone, twist an opening pick in one of the edges to help separate the back cover from the frame.
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly, this is a good point to power on your phone and test all functions before you seal the back cover in place. Be sure to power your phone back down completely before you continue working.
    • Follow this guide to reinstall the back cover, transfer and install the camera bezel, and replace the adhesive.
  10. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Remove the midframe: 10 단계, 이미지 1개 중 1개
    • Remove the nine 4 mm Phillips screws securing the top midframe to the phone.
  11. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 11 단계, 이미지 2개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 11 단계, 이미지 2개 중 2개
    • The midframe is still held in place by a few plastic clips around the edge.
    • Insert the point of a spudger into the notch on the right edge of the midframe, near the Bixby button.
    • Pry up to loosen the midframe from the phone.
  12. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 12 단계, 이미지 2개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 12 단계, 이미지 2개 중 2개
    • Insert the point of a spudger into the notch on the left edge of the phone, located near the power button.
  13. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 13 단계, 이미지 1개 중 1개
  14. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Disconnect the battery: 14 단계, 이미지 3개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Disconnect the battery: 14 단계, 이미지 3개 중 2개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Disconnect the battery: 14 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger underneath the battery connector, which is attached to the motherboard below the rear-facing camera.
    • Pry upwards to disconnect the connector from its socket.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Gently push the battery's flex cable away from the motherboard socket to prevent accidental contact.
  15. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Remove the loudspeaker: 15 단계, 이미지 1개 중 1개
    • Remove the seven 4 mm Phillips screws securing the lower midframe to the phone.
  16. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 16 단계, 이미지 2개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 16 단계, 이미지 2개 중 2개
    • Insert the point of a spudger in the notch near the bottom right corner of the lower midframe. It is marked by a small triangle.
    • Pry up to release the midframe from the phone.
  17. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 17 단계, 이미지 3개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 17 단계, 이미지 3개 중 2개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 17 단계, 이미지 3개 중 3개
    • Grasp the loosened end of the midframe with your fingers and lift upwards slowly.
    • Wiggle the midframe slightly to help release the remaining edge clips.
    • Remove the lower midframe. The loudspeaker is built into the lower midframe.
    • To reinstall the lower midframe, align the midframe's bottom edge to to the phone edge, and press it into place.
  18. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Motherboard: 18 단계, 이미지 2개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Motherboard: 18 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the display connector from its motherboard socket, located near the bottom right corner of the phone.
  19. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 19 단계, 이미지 2개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 19 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the headphone jack's connector from its motherboard socket.
  20. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 20 단계, 이미지 1개 중 1개
    • Remove the three Phillips screws securing the motherboard to the phone:
    • One 3.8 mm screw
    • Two 3.7 mm screws
  21. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 21 단계, 이미지 2개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 21 단계, 이미지 2개 중 2개
    • Insert the point of a spudger underneath the right edge of the motherboard, near the volume up button.
    • Pry up gently to loosen the motherboard from its recess.
  22. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 22 단계, 이미지 3개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 22 단계, 이미지 3개 중 2개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 22 단계, 이미지 3개 중 3개
    • Using your fingers, grasp the motherboard by the top corners.
    • Lift the motherboard edge slightly out of its recess. Be careful not to snag any cables along the way.
    • Pull the motherboard towards the top edge of the phone while wiggling the board slightly. This will loosen the charging port from its socket.
    • Once the charging port is freed from its socket, remove the motherboard.
    • To reinstall the motherboard, align the motherboard's charging port with the bottom edge of the phone.
    • Gently push the motherboard against the bottom edge of the phone until the charging port is completely seated.
    • Lower the motherboard and press into place. Be careful not to trap any cables underneath the motherboard. The board should sit flush against the frame.
  23. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Rear-Facing Camera Module: 23 단계, 이미지 3개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Rear-Facing Camera Module: 23 단계, 이미지 3개 중 2개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement, Rear-Facing Camera Module: 23 단계, 이미지 3개 중 3개
    • Flip the motherboard over.
    • Use the flat end of a spudger to pry up and disconnect the two camera connectors from their sockets on the motherboard.
  24. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 24 단계, 이미지 1개 중 1개
    • Heat an iOpener and lay it over the rear-facing camera module for one minute. This helps loosen the adhesive holding the camera module to the motherboard.
  25. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 25 단계, 이미지 2개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 25 단계, 이미지 2개 중 2개
    • Insert the point of a spudger under the top-left corner of the camera module, where there is a small notch.
    • Pry up to loosen the camera module from the motherboard.
  26. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 26 단계, 이미지 2개 중 1개 Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 26 단계, 이미지 2개 중 2개
    • Insert the edge of an opening tool under the loosened corner of the camera module.
    • Pry up to release the camera module from the motherboard.
    • Continue prying around the camera module with the opening tool until the module is freed from the motherboard.
  27. Samsung Galaxy S10+ Rear-Facing Camera Module Replacement: 27 단계, 이미지 1개 중 1개
    • Remove the rear-facing camera module.
결론
After you've completed the repair, follow this guide to test your repair.
다른 13명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Arthur Shi
회원 가입일: 01/03/18
310,126 평판
안내서 701개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,638개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 96
전체 시간: 7,061
